Vista - Vista Sound Echo
Old 08-11-2007   #1 (permalink)
Guildwoodpearce
Vista Sound Echo
I just got a new dell computer with windows vista, and everything has an
echo, videos and music, even the sounds within windows. Is this a common
problem? and how do i fix it?
Old 08-11-2007   #2 (permalink)
GWL
RE: Vista Sound Echo
Check your sound card settings. It sounds like it may be set on Concert
Hall. What it is called depends on what sound card or chip you have on your
machine.
Old 08-12-2007   #3 (permalink)
Cheddarhead
Re: Vista Sound Echo
Use a Q-tip
"GWL" <GWL@discussions.microsoft.com> wrote in message news:13B39F74-793B-4C0C-87B1-0BCBE0B4EFDC@microsoft.com...
> machine.
Old 08-12-2007   #4 (permalink)
Guildwoodpearce
problem fixed, thanks GWL
"Cheddarhead" wrote:
> Use a Q-tip
> > machine.
Solved Sound Echo problem Solved Sound & Audio
echo in sound Sound & Audio
How to save output of echo to a file or omit using echo and save it VB Script
Echo sound when watching tv channels using vista media center Vista music pictures video
How to disable ICMP echo requests (Ping) on Windows Vista Home Bas Vista security
