| | Mcaffe Problems I tried to install Mcaffe Security on my computer (Vista Beta2 Build 5384) and was told it failed, did I want to run it with better settings, so I clicked yes, it then installed but gave an error saying it wasn't compatable with the version of windows I have, so I tried to uninstall but it says the program is not compatable, so I cant remove it and I cant install any more anti virus software until Mcaffe is gone! I've tried deleting all the program files for it and removed it from the start up but I still cant get shot of it What can I do now? |
| | Re: Mcaffe Problems Since I got no response to an earlier post on a similar problem, you will probably have to manually remove it or may be able to do it partially manually and use one of the registry cleaners to remove the registry entries after manually removing the program from 'Programs'. Good luck. "RobRobson" <RobRobson@discussions.microsoft.com> wrote in message news:F2AC5E99-7933-49C6-988C-50E81CA71F81@microsoft.com... >I tried to install Mcaffe Security on my computer (Vista Beta2 Build 5384) > and was told it failed, did I want to run it with better settings, so I > clicked yes, it then installed but gave an error saying it wasn't > compatable > with the version of windows I have, so I tried to uninstall but it says > the > program is not compatable, so I cant remove it and I cant install any more > anti virus software until Mcaffe is gone! > > I've tried deleting all the program files for it and removed it from the > start up but I still cant get shot of it > > What can I do now? |
| | Re: Mcaffe Problems You'll have to do a registry search for anything McAfee or Network Associates or NAI and delete. Try asking for help at http://forums.mcafeehelp.com/ -- Peter Toronto, Canada P4 D865GBF HT @ 3.0ghz 2.0gb DDR 450gb HD ATI Radeon 9550 Graphics Creative Soundblaster Audigy 4 Audio "RobRobson" <RobRobson@discussions.microsoft.com> wrote in message news:F2AC5E99-7933-49C6-988C-50E81CA71F81@microsoft.com... >I tried to install Mcaffe Security on my computer (Vista Beta2 Build 5384) > and was told it failed, did I want to run it with better settings, so I > clicked yes, it then installed but gave an error saying it wasn't > compatable > with the version of windows I have, so I tried to uninstall but it says > the > program is not compatable, so I cant remove it and I cant install any more > anti virus software until Mcaffe is gone! > > I've tried deleting all the program files for it and removed it from the > start up but I still cant get shot of it > > What can I do now? |
| Problems with new Logitech S-150 speakers problems with x64 vista | Sound & Audio | |||
| Big vista problems need help icon/background/graphics/personalise problems | Vista performance & maintenance | |||
| Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 | Vista General | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
