Vista - system restore not working
Old 08-12-2007   #1 (permalink)
cyng
I am trying to use my system restore on my new computer with Vista. When I
try to use system restore it says that there are no backups available. Then
when I go into System Properties to make sure that it is turned on, in the
box where it checks for Automatic restore points, it keeps saying that it is
searching for available disks, but never displays any. I know that a few
weeks ago it was working when I checked it.
Old 08-13-2007   #2 (permalink)
Bert Kinney
Re: system restore not working
Hi Cyng,
Just to be clear, when you open System Properties - System Protection it
starts scanning of available drives?
When there, are there any Available Disks visible, and are any of them checked?
Regards,
Bert Kinney MS-MVP Shell/User
http://bertk.mvps.org
Member: http://dts-l.org
Old 08-13-2007   #3 (permalink)
cyng
Hi Bert--
No, it doesn't show any drives available when it opens -- it just says that
it's searching for available drives and it keeps searching (I've waited about
10 minutes) and doesn't stop. Thanks.
--Cyng
"Bert Kinney" wrote:
> Hi Cyng,
> Regards,
System restore not working Vista performance & maintenance
System Restore not working Vista General
System restore not working! Vista General
System Restore not working Vista security
