| Guest | External LCD Monitor has no red color In the course of updating drivers and adjusting configuration, I lost the ability of my external LCD monitor to display any red color, however the color displays fine on the laptop screen. I think the problem is caused by a Vista configuration because red does appear in the DOS pop-up screen that opens when I check the monitor's manual adustment. My system is a Lenovo T60 (dual CPU, 1.5 MB RAM, 100 GB HD) with Vista Business 32 bit preinstalled. The graphics configuration includes an ATI Radeon 1400 & ATI's Catalyst Control, Spyder2Express color calibration, ThinkPad LCD screen (1450x1050), and a Dell Ultrasharp 17" 1704 LCD monitor connected to the laptop through an XGA cable (no DVI socket on Thinkpad). All downloads are current and there's no obviously incorrect setting that I can see in any of the above. I've uninstalled and reinstalled all the video related drivers. I'd appreciate any suggestions. Thanks, Phil |
| Guest | Re: External LCD Monitor has no red color PhiAlv wrote: > In the course of updating drivers and adjusting configuration, I lost the > ability of my external LCD monitor to display any red color, however the > color displays fine on the laptop screen. I think the problem is caused by a > Vista configuration because red does appear in the DOS pop-up screen that > opens when I check the monitor's manual adustment. > My system is a Lenovo T60 (dual CPU, 1.5 MB RAM, 100 GB HD) with Vista > Business 32 bit preinstalled. The graphics configuration includes an ATI > Radeon 1400 & ATI's Catalyst Control, Spyder2Express color calibration, > ThinkPad LCD screen (1450x1050), and a Dell Ultrasharp 17" 1704 LCD monitor > connected to the laptop through an XGA cable (no DVI socket on Thinkpad). All > downloads are current and there's no obviously incorrect setting that I can > see in any of the above. > I've uninstalled and reinstalled all the video related drivers. > I'd appreciate any suggestions. > Thanks, > Phil It's the VGA cable OR the VGA connector on the laptop - give it some gentle pressure and see if the red comes back... Try another VGA cable if you can... Guy |
| Guest | Re: External LCD Monitor has no red color Hi Bigguy, Thanks, I think you were right. Does that mean that the monitor's hard adjustment features are hardwired into it and don't use the connection to the laptop at all? Regards, Phil "Bigguy" wrote: > PhiAlv wrote: > > In the course of updating drivers and adjusting configuration, I lost the > > ability of my external LCD monitor to display any red color, however the > > color displays fine on the laptop screen. I think the problem is caused by a > > Vista configuration because red does appear in the DOS pop-up screen that > > opens when I check the monitor's manual adustment. > > My system is a Lenovo T60 (dual CPU, 1.5 MB RAM, 100 GB HD) with Vista > > Business 32 bit preinstalled. The graphics configuration includes an ATI > > Radeon 1400 & ATI's Catalyst Control, Spyder2Express color calibration, > > ThinkPad LCD screen (1450x1050), and a Dell Ultrasharp 17" 1704 LCD monitor > > connected to the laptop through an XGA cable (no DVI socket on Thinkpad). All > > downloads are current and there's no obviously incorrect setting that I can > > see in any of the above. > > I've uninstalled and reinstalled all the video related drivers. > > I'd appreciate any suggestions. > > Thanks, > > Phil > It's the VGA cable OR the VGA connector on the laptop - give it some > gentle pressure and see if the red comes back... > Try another VGA cable if you can... > > Guy > |
| Guest | Re: External LCD Monitor has no red color Yep, that's right - the monitor self-test is internally generated so if it shows red the monitor is okay. I'd suspect the cable or the connection at the PC or monitor end. -- Richard G. Harper [MVP Shell/User] rgharper@gmail.com * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ * HELP us help YOU ... http://www.dts-l.org/goodpost.htm "PhiAlv" <PhiAlv@discussions.microsoft.com> wrote in message news:63FDD9EB-BDBD-4C18-9238-EACFF4F971A7@microsoft.com... > Hi Bigguy, > > Thanks, I think you were right. Does that mean that the monitor's hard > adjustment features are hardwired into it and don't use the connection to > the > laptop at all? > > Regards, > > Phil > > "Bigguy" wrote: > >> PhiAlv wrote: >> > In the course of updating drivers and adjusting configuration, I lost >> > the >> > ability of my external LCD monitor to display any red color, however >> > the >> > color displays fine on the laptop screen. I think the problem is caused >> > by a >> > Vista configuration because red does appear in the DOS pop-up screen >> > that >> > opens when I check the monitor's manual adustment. >> > My system is a Lenovo T60 (dual CPU, 1.5 MB RAM, 100 GB HD) with Vista >> > Business 32 bit preinstalled. The graphics configuration includes an >> > ATI >> > Radeon 1400 & ATI's Catalyst Control, Spyder2Express color calibration, >> > ThinkPad LCD screen (1450x1050), and a Dell Ultrasharp 17" 1704 LCD >> > monitor >> > connected to the laptop through an XGA cable (no DVI socket on >> > Thinkpad). All >> > downloads are current and there's no obviously incorrect setting that I >> > can >> > see in any of the above. >> > I've uninstalled and reinstalled all the video related drivers. >> > I'd appreciate any suggestions. >> > Thanks, >> > Phil >> It's the VGA cable OR the VGA connector on the laptop - give it some >> gentle pressure and see if the red comes back... >> Try another VGA cable if you can... >> >> Guy >> |
| Monitor Color profile kicked out | Vista music pictures video | |||
| Changing color profiles for a monitor | Vista General | |||
| Color Managment: is ICC monitor profile applied to the whole deskt | Vista General | |||
| Problems using external T.V as external second monitor vai S-Video | Vista installation & setup | |||
| Monitor Color Profiles | Vista hardware & devices | |||
