| | Very odd icon overlay problem I've just restarted my PC after doing some changes - which included using TWEAKUI to try and get rid of the annoting shortcut arrows on the desktop and now find that over every destop icon there is another one which looks like a hard disk icon with a ring above it. How can I get rid of them? Yes I know I should have known better than to use the TWEAKUI for XP !! TIA cheers, Len |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Very odd icon overlay problem I've just restarted my PC after doing some changes - which included using TWEAKUI to try and get rid of the annoting shortcut arrows on the desktop and now find that over every destop icon there is another one which looks like a hard disk icon with a ring above it. How can I get rid of them? Yes I know I should have known better than to use the TWEAKUI for XP !! TIA cheers, Len You might try using this program called "Frameworkx". It may help replace those messed up shortcut overlays from "TweakUI XP" with one that works right. Frameworkx Hope it helps you, Shawn |
| | Re: Very odd icon overlay problem On Mon, 13 Aug 2007 11:23:32 -0500, brink <brink.2v9iw1@no-mx.forums.net> wrote: > >Len Cuff;419269 Wrote: >> I've just restarted my PC after doing some changes - which included >> using TWEAKUI to try and get rid of the annoting shortcut arrows on >> the desktop and now find that over every destop icon there is another >> one which looks like a hard disk icon with a ring above it. How can I >> get rid of them? >> >> Yes I know I should have known better than to use the TWEAKUI for XP >> !! >> >> TIA >> >> >> cheers, >> Len > >Hi Len, > >You might try using this program called "Frameworkx". It may help >replace those messed up shortcut overlays from "TweakUI XP" with one >that works right. > >'Frameworkx' >(http://www.frameworkx.com/Frameworkx...on.aspx?id=632) > >Hope it helps you, >Shawn Many thanks, sorted it straight away! cheers, Len |
| | RE: Very odd icon overlay problem The Tweak Vista site has the answer. You may have to search. I did it awhile ago (removed all the shortcut arrows) http://www.tweakvista.com/VistaInterfaceTweaks.aspx Cheers, Lara "Len Cuff" wrote: > I've just restarted my PC after doing some changes - which included > using TWEAKUI to try and get rid of the annoting shortcut arrows on > the desktop and now find that over every destop icon there is another > one which looks like a hard disk icon with a ring above it. How can I > get rid of them? > > Yes I know I should have known better than to use the TWEAKUI for XP > !! > > TIA > > > cheers, > Len > |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Very odd icon overlay problem On Mon, 13 Aug 2007 11:23:32 -0500, brink <brink.2v9iw1@no-mx.forums.net> wrote: > >Len Cuff;419269 Wrote: >> I've just restarted my PC after doing some changes - which included >> using TWEAKUI to try and get rid of the annoting shortcut arrows on >> the desktop and now find that over every destop icon there is another >> one which looks like a hard disk icon with a ring above it. How can I >> get rid of them? >> >> Yes I know I should have known better than to use the TWEAKUI for XP >> !! >> >> TIA >> >> >> cheers, >> Len > >Hi Len, > >You might try using this program called "Frameworkx". It may help >replace those messed up shortcut overlays from "TweakUI XP" with one >that works right. > >'Frameworkx' >(Frameworkx) > >Hope it helps you, >Shawn Many thanks, sorted it straight away! cheers, Len Glad to hear it helped and thank you for the feedback. Shawn |
| Problem With Title Overlay on WMM | Vista music pictures video | |||
| Offline Files Icon Overlay | Vista networking & sharing | |||
| weird "icon overlay" problem with TortoiseCVS | Vista General | |||
| "Run as administrator" icon overlay won't go away | Vista General | |||
| Strange Folder Icon Overlay | Vista General | |||
