location is not available help
  1.    14 Aug 2007 #1
    Brad Guest
    Hi
    after receiving windows updates i get this location is not available
    c:\windows\system32\config\systemprofile\desktop refers to a location that is
    unavailable. it could be on a hard drive on this computer.or on a network.
    check to make sure that the disk is properly inserted, or that you are
    connected to the internet or your network and then try again. if it still
    cannot be located the information might have been moved to a different
    location. {i am connected net} it happens when ever i try to d/l anything to
    the desktop.
    thank you i have vista home premium
  2.    14 Aug 2007 #2
    dean-dean Guest
    Re: location is not available help
    Try this. Go to C:\Users\(You) and right click on the Desktop folder and
    choose Properties. On the Location tab, click on Restore Default. Then go
    to C:\Users\Public and do the same for the (hidden) Public Desktop folder.
    "Brad" <Brad@discussions.microsoft.com> wrote in message
    news:3734AB08-B798-419A-A1F5-59E9249222C8@microsoft.com...
    > Hi
    > is
    > to
    > the desktop.
  3.    18 Sep 2007 #3
    landin Guest
    RE: location is not available help
    "Brad" wrote:
    > Hi
    > the desktop.
  4.    18 Sep 2007 #4
    landin Guest
    Has this issue been resolved? I have a client that is calling me about the
    same message. I want to gather as much information about this before I sit
    down behind her notebook.
    "Brad" wrote:
    > Hi
    > the desktop.
  5.    09 Feb 2008 #5
    Vista Home Premium 32bit
    Local Time: 21:24
    We have the same problem. if you discover the solution I'd appreciate very much if you could post it in this forum (in plain english). Thanks a lot. I have Vista home premium as well.
  6.    25 Feb 2008 #6
    Vista Ultimate 32 bit
    Local Time: 20:24
    (i hope this helps) I was downloading some files using Bitlord and when i tried looking for them they couldn't be found. I got the same message as the one posted above...
    C:\Program Files\BitLord\Downloads\filename refers to a location that is unvailable. It could be on a hard drive on this computer or on a network. Check to make sure that the disk is properly inserted, or that you are connected to the internet or your network, and then try again. If it still cannot be located, the informaiton might have been moved to a different location.
    Anyways, all I had to do is go to the folder where my files were supposed to be and click on the "compatibility files" tab and there it was. So everytime I have to access this files I simply go to the folder where my files are supposed to be and click on the tab called "compatibility files" so i can fully see my files. I hope this helps. BYE!!!
  7.    15 Nov 2008 #7
    Vista
    Local Time: 19:24
    Hi, I'm new to this site, but I was having the same difficulties w/"this location not available". I followed the directions to "restore" defaults" and it has worked so far. I was trying to use an SD Memory Card and the drive wasn't there... after restoring, I put the memory card in the computer and it found the card! Thank you!
    Crystal
  8.    25 Aug 2009 #8
    g2dcracker Guest
    *The solution is Very simple ..*
    Restart your PC and as soon as it reboots press F8 continuosly(on and
    off).
    It should land you to a screen with many options to start windows like
    -starts window normally
    * [ S I Z E = \ " 5 \ " ] - L a s t k n o w n g o o d c o n f i g
    u r a t i o n t h a t w o r k e d . . [/SIZE]*
    Etc Etc..
    Choose last known good configuration (using arrow keys ) and press
    enter..
    Your windows has restore your settings now...
    Enjoy..
    Hope and wish the solution should work for all..
    Best of luck..
    If this worked jus say hi on the next reply...
    g2dcracker
    g2dcracker's Profile: http://forums.techarena.in/members/128494.htm
    View this thread: http://forums.techarena.in/vista-help/801087.htm
  9.    06 Jan 2010 #9
    beachlite94 Guest
    I FOUND OUT AN ANSWER!!
    alright it's either one of these.
    Go to my computer then C:\Users\
    then right click on whatever your username is.
    Hit properties
    then hit advanced, and hit file is ready for archiving.
    I think that's the one that did it, but if that doesn't work,
    go to security, and change every one of the users and people in there
    , and check every single thing. It will say it denies it a few times
    for awhile.
    Hope I helped!!
    beachlite94
    beachlite94's Profile: http://forums.techarena.in/members/171478.htm
a folder in C:\Users\username\Documents has gone missing. I can find the folder and all its contents when i run a search in the start menu, however i...
General Discussion
Please help!! - location is not available???
Hey People, system specs Windows Vista Ultimate, 64 bit, SP2 I was playing around with the permissions for one of my secondary drives that...
Network & Sharing
location is not available..?
Hi I am having Windows Vista Home premium. when i access the My Computer i am getting this Message The location is not available...
Vista General
Re: LOCATION IS NOT AVAILABLE
"HankL" <hlaskin@xxxxxx> wrote in message news:8954E756-3BEE-42AA-90BF-4E254B4B8156@xxxxxx
Vista General
BUG? Invalid location after Set-Location \\MyMachine
Let's invoke the following command (where \\MyMachine is the existing network name): 0> Set-Location \\MyMachine Set-Location : Command...
PowerShell
More appropriate location
Traffic looks very light here for a new technology. I am assuming there is a more appropriate place to get WCF help? MSDN forums perhaps?
Indigo
Set-Location bug??
If I type this into PoSH RC2: > set-location // -ea:stop I get an error message but I also wind up in the location:...
PowerShell
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
