| | Sidebar problem Hi I'm having a problem with my side bar. Someone put some papers on my keyboard and it ended up pushing some buttons on my keyboard and what it had been doing was openoing the calendar function on my side bar. It added the aplication about 150 times so everytime i restart my pc it tries to load the calendare function 150 times resulting in my pc freezing. Once this has happend there is no way of accesing any function in side bar. I have managed to stop it starting on start up but how do i remove all those aplications so I have use of my side bar again |
| | Re: Sidebar problem Hi, You'll find the list of programs that are loaded in a settings.ini file in this directory: C:\Users\<user>\AppData\Local\Microsoft\Windows Sidebar I would recommend backing up this file on the desktop before manipulating the data in it. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Saffa" <Saffa@discussions.microsoft.com> wrote in message news:8E081CB7-1B3F-4692-8243-0EDCB446BB86@microsoft.com... > Hi > I'm having a problem with my side bar. Someone put some papers on my > keyboard and it ended up pushing some buttons on my keyboard and what it > had > been doing was openoing the calendar function on my side bar. It added the > aplication about 150 times so everytime i restart my pc it tries to load > the > calendare function 150 times resulting in my pc freezing. Once this has > happend there is no way of accesing any function in side bar. I have > managed > to stop it starting on start up but how do i remove all those aplications > so > I have use of my side bar again |
| Sidebar problem | Vista General | |||
| Another Sidebar Problem | Vista General | |||
| sidebar problem | Vista General | |||
| Sidebar problem! Please help! | Vista General | |||
| Problem with Sidebar and Screensaver | Vista performance & maintenance | |||
