| | Vista supported Wireless USB Drive & PCI Card Hello All, I have a Netgear WG111 USB Adapter, which doesn't work with Vista. I am looking for a new USB Adapter / PCI Card which is supported by Vista (Installed & worked with no hassles). I tried to find a forum which shows this information, but I couldn't get one. Can anyone update this with Information for following: 1) Which Wireless USB Adapter / PCI Cards are supported by Vista? 2) Where can I find best information about above (Links if possible)? Thanks in Advance. |
| | Re: Vista supported Wireless USB Drive & PCI Card Aside from the manufactures' sites you might try PROnetworks at http://www.pro-networks.org/. There are tons of Vista stuff there including software. "Kode" <Kode@discussions.microsoft.com> wrote in message news:6BD559A8-9EFF-426D-9E60-4AC47156D678@microsoft.com... > Hello All, > > I have a Netgear WG111 USB Adapter, which doesn't work with Vista. > I am looking for a new USB Adapter / PCI Card which is supported by Vista > (Installed & worked with no hassles). > I tried to find a forum which shows this information, but I couldn't get > one. > Can anyone update this with Information for following: > > 1) Which Wireless USB Adapter / PCI Cards are supported by Vista? > > 2) Where can I find best information about above (Links if possible)? > > Thanks in Advance. |
| | Re: Vista supported Wireless USB Drive & PCI Card I have a Ralink rt2500 chipset on my wireless pci card. The drivers were installed when Vista x64 installed. I’m running Windows x64 and Vista x64 (5384). Wireless cards using this chipset are listed at “http://ralink.rapla.net/”. I haven’t installed Vista 32 bit so I don’t know about 32-bit drivers but they also should be available out of the box. "Kode" <Kode@discussions.microsoft.com> wrote in message news:6BD559A8-9EFF-426D-9E60-4AC47156D678@microsoft.com... > Hello All, > > I have a Netgear WG111 USB Adapter, which doesn't work with Vista. > I am looking for a new USB Adapter / PCI Card which is supported by Vista > (Installed & worked with no hassles). > I tried to find a forum which shows this information, but I couldn't get > one. > Can anyone update this with Information for following: > > 1) Which Wireless USB Adapter / PCI Cards are supported by Vista? > > 2) Where can I find best information about above (Links if possible)? > > Thanks in Advance. |
| | Re: Vista supported Wireless USB Drive & PCI Card "Kode" <Kode@discussions.microsoft.com> wrote in message news:6BD559A8-9EFF-426D-9E60-4AC47156D678@microsoft.com... > Hello All, > > I have a Netgear WG111 USB Adapter, which doesn't work with Vista. > I am looking for a new USB Adapter / PCI Card which is supported by Vista > (Installed & worked with no hassles). > I tried to find a forum which shows this information, but I couldn't get one. > Can anyone update this with Information for following: > > 1) Which Wireless USB Adapter / PCI Cards are supported by Vista? > > 2) Where can I find best information about above (Links if possible)? > > Thanks in Advance. Did you try installing the drivers for XP? Sometimes, the drivers/installation program will work in Vista. -Michael |
| Vista Supported Wireless USB Adapter / Wireless PCI Card | Vista General | |||
| Toshiba L305-S5884 wireless card and hard drive issue on Vista | Vista General | |||
| Help finding USB Wireless N adapter supported in Vista x64 | Drivers | |||
| no DX 10 supported driver on first DX10 supported card | Vista General | |||
| sound card not supported | Vista General | |||
