Vista - Vista Supported Wireless USB Adapter / Wireless PCI Card
Old 06-27-2006   #1 (permalink)
Kode
Hello All,
I have a Netgear WG111 USB Adapter, which doesn't work with Vista.
I am looking for a new USB Adapter / PCI Card which is supported by Vista
(Installed & worked with no hassles).
I tried to find a forum which shows this information, but I couldn't get one.
Can anyone update this with Information for following:
1) Which Wireless USB Adapter / PCI Cards are supported by Vista?
2) Where can I find best information about above (Links if possible)?
Thanks in Advance.
Old 06-27-2006   #2 (permalink)
DJ Bjorklund
Re: Vista Supported Wireless USB Adapter / Wireless PCI Card
On Tue, 27 Jun 2006 14:35:01 -0700, Kode
<Kode@discussions.microsoft.com> wrote:
>Hello All,
>Thanks in Advance.
My Linksys WUSB11 Ver 2.6 ("B" spec) works fine under 5384
Not at home, but I'm pretty sure I'm close on the model and version
Old 06-28-2006   #3 (permalink)
Hope
I'm using a Linksys A/G USB adapter which is working fine.
"Kode" <Kode@discussions.microsoft.com> wrote in message
news:54BE7F5E-5999-4900-94AA-8099979D37B5@microsoft.com...
> Hello All,
> one.
> Thanks in Advance.
Old 01-19-2009   #4 (permalink)
Vista home basic
Re: Vista Supported Wireless PCI Card
i have a PCI G wireless card in my desktop with Vista Home Basic and it keeps dropping my wireless connection or it gets a weak signal. I'm only about 20 ft from the router. However, it sometimes picks up my neighbors network.
Anyone out there can recommend either a USB or another PCI card that has Vista drivers and works with a Linksys N router?
thanking you in advance.
Old 01-25-2009   #5 (permalink)
Mellowed
> network.
I use this one with my laptop.
http://www.newegg.com/Product/Produc...82E16833314032
It allows the optimizing of the antenna location. My home router is
an EDIMAX 'N'. No problems on the road.
help with network (usb wireless adapter or wireless router) Network & Sharing
Dell Wireless WLAN Card Wireless Network Controller has stopped working Network & Sharing
Wireless network adapter card issues w/ Vista Vista General
Help finding USB Wireless N adapter supported in Vista x64 Drivers
Vista supported Wireless USB Drive & PCI Card Vista General
