Vista - Possible Problem With Vista Performance Pack KB938979
Old 08-16-2007   #1 (permalink)
George Dingwall
Hi all,
After downloading and installing this update, I found that my menus
were behaving differently to normal. When you clicked on a menu or
sub-menu option in any program, the menus would cascade out to the
left, instead of to the left as they had previously done.
Uninstalling the update put the menus back to normal.
Has anybody else who has installed this update had a similar problem?
In case you are wondering what the hell I'm talking about, have a look
at these two screen shots to see the before and after effect.
The before image.
http://www.georgedingwall.co.uk/imag...p/MenusOld.jpg
The after image.
http://www.georgedingwall.co.uk/images/temp/Menus.jpg
Bye for now,
George Dingwall
Invergordon, Scotland
Old 08-16-2007   #2 (permalink)
Paul Smith
Re: Possible Problem With Vista Performance Pack KB938979
If you've got Tablet PC settings under Hardware and Sound in Control Panel,
go and check the left-right handed settings, they swap the menus around.
Paul Smith,
Yeovil, UK.
Microsoft MVP Windows Shell/User.
http://www.dasmirnov.net/blog/
http://www.windowsresource.net/
*Remove nospam. to reply by e-mail*
"George Dingwall" <george.gdingwall@virgin.net> wrote in message
news:5g69c35p1f195trkf2j6e4upben9oathk7@4ax.com...
> Hi all,
> The before image.
> The after image.
> Bye for now,
> George Dingwall
Old 08-16-2007   #3 (permalink)
Dave Cox
George Dingwall <george.gdingwall@virgin.net> wrote in
news:5g69c35p1f195trkf2j6e4upben9oathk7@4ax.com:
> Hi all,
> menus were behaving differently to normal. When you clicked on a
> menu or sub-menu option in any program, the menus would cascade
> out to the left, instead of to the left as they had previously
> done.
> problem?
> look at these two screen shots to see the before and after effect.
> The before image.
> The after image.
> Bye for now,
> George Dingwall
That is the way it is suppose to work the menus will fly out in the
direction with the most available room. As your pictures show IE is
larger and more centered therefore the menus can cascade to the
right, in the second picture IE is smaller and to the right
therefore the menus will cascade to the left. there is nothing
wrong.
The most reliable time to upgrade to a new Operating System is at the
end of its life cycle.
Dave
Old 08-16-2007   #4 (permalink)
George Dingwall
On Thu, 16 Aug 2007 19:56:52 +0100, "Paul Smith"
Hi Paul,
Thanks for that tip. I've just re-installed the update, and it changed
the handedness setting in the Tablet PC options so that menus were
flying out from the left instead of how it was previously from the
right.
I was beginning to go mad over this, as people I know who have also
installed the update did not have the same problem.
Thanks again, Paul, I really appreciate your help. I spent over two
hours on the phone, and with remote desktop access today, and they did
not think of that solution. I'm well pleased.
Bye for now,
George Dingwall
Old 08-16-2007   #5 (permalink)
Synapse Syndrome
"Dave Cox" <dcox1961@gmail.com> wrote in message
news:Xns998E7FC87FAAdcoxgmailcom@69.28.186.121...
> wrong.
Wrong. Look at the arrows on the menu in the picture. He has already got
the solution to the problem, but it is strange that the update had changed
the registry key (or whatever) involved.
ss.
Old 08-16-2007   #6 (permalink)
DP
> wrong.
You are correct, Dave. The two photos are apples-and-oranges comparisons
because the IE window is in a different place. The only reliable comparison
is to do it pre and post-upgrade with the IE window in the same spot both
times.
Old 08-16-2007   #7 (permalink)
DP
"Synapse Syndrome" <synapse@NOSPAMgomez404.elitemail.org> wrote in message
news:%23%23alymE4HHA.4900@TK2MSFTNGP04.phx.gbl...
>> wrong.
Nope, Dave is correct. I just tested it myself. And even though I got the
menus to swing out to the left, the arrows were still pointing right.
Old 08-16-2007   #8 (permalink)
DP
>> wrong.
Old 08-16-2007   #9 (permalink)
Synapse Syndrome
"DP" <nospam@nospam.com> wrote in message
news:ehTQKLG4HHA.5740@TK2MSFTNGP04.phx.gbl...
>> wrong.
> comparison is to do it pre and post-upgrade with the IE window in the same
> spot both times.
Wrong. Look at the positions of the flyout arrows on the IE menus. That
can only happen in left-hand mode.
ss.
Old 08-16-2007   #10 (permalink)
DP
The arrows are on the right side in both cases. If you take your IE window
and move it to the right of your screen and click on Favorites dropdwon
menu, the menus fly out to the left even though the arrows are pointing
right.
If you move the IE window to the right side of your screen, the arrows point
to the right and the menus fly out to the right.
Have you tried this?
Or am I misunderstanding what you're saying?
The menus fly out to wherever they can find space, left or right, but the
arrows always point right.
news:OHyKngG4HHA.3400@TK2MSFTNGP03.phx.gbl...
>>> wrong.
>> same spot both times.
> ss.
Vista Ultimate Windows Update Problem 2 (KB938979) Vista General
Help is on the way Vista Performance and Reliability Pack Vista General
VISTA Performance Service Pack Vista performance & maintenance
***Performance issue? I found a Vista service pack 1 Vista performance & maintenance
