| | RE: help please???? you are right but the deal is when i download it nothing changes, it's like the computer telling me that it's been installed correctly but i still can't run these pages. "shortwoman" wrote: > You need to go ahead & download the flash plug-in > because some items will not run correct without > this program. > shortwoman > > "Ray" wrote: > > > Hi everyone, i have a problem with my IE7 running on vista home premium. the > > problem i am having is, when ever i access a website running a flash i keep > > getting a message that i need to download the flash plug-in. please advise > > that i almost tried everything. i have tried checking the add-ons to make > > sure they are enabled, and they all are. i have tried changing the security > > options and the cookies to try and install it, but with no luck. what > > confuses me is that it was running fine before, and i tried using the system > > restore, but also nothing happend. when i try downloading it from flash > > website i get the successfuly installed flash player but it doesn't change > > anything. please if anyone can help me, i'll raelly appreciate it. one more > > thing it works fine with firefox when i installed the flash add-on for it. > > > > Thanks, |
