Vista - Going crazy...need to change color!
Old 08-16-2007   #1 (permalink)
Sarah
I just got Windows Vista and my Taskbar and start menu are black...I can't
get them to change color. I'm sure it's simple, but no menu I have found will
change it.
Old 08-16-2007   #2 (permalink)
The Sand
RE: Going crazy...need to change color!
Hi Sarah, I'm not sure this will help but I went to Control Panel,
Personalization, Window Color and Appearance... and then I selected the
"color mixer" and slid the bar around until I got green. Now my windows,
start menu and task bar are green. Hope that helps...
Sandy
"God is my backup"
> change it.
Old 08-16-2007   #3 (permalink)
romanom
Right click any place on the desktop (where there are no icons) and click on
Personalize. The personalization window pops up and the choices are
self-explanatory.
> Sandy
> "God is my backup"
> > change it.
HELP with color change!!!!!! General Discussion
Can't change Color of pages using color/appearance Vista installation & setup
Change the color scheme Vista General
FSX Color scheme change Vista Games
change tab color Vista General
