Remote Desktop with dual monitors problem
  1. #1
    Riccardo Guest
    When I connect to a remote PC (both Vista Enterprise) with dual monitor
    using remote desktop, I can't see the sidebars I created (apart from the Ms
    Taskbar). I only see an empty frame without any icons. Also the /span switch
    doesn't seems to work.
    Any suggestion?
  2. #2
    Richard G. Harper Guest
    Re: Remote Desktop with dual monitors problem
    I don't believe Remote Desktop supports dual display use.
    Richard G. Harper [MVP Shell/User] rgharper@gmail.com
    * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
    * PLEASE post all messages and replies in the newsgroups
    * The Website - http://rgharper.mvps.org/
    * HELP us help YOU ... http://www.dts-l.org/goodpost.htm
    "Riccardo" <riccardo@nospam.it> wrote in message
    news:OXEpmSL4HHA.1188@TK2MSFTNGP04.phx.gbl...
    > Ms Taskbar). I only see an empty frame without any icons. Also the /span
    > switch doesn't seems to work.
    > Any suggestion?
Remote Desktop with dual monitors problem problems?
Dual monitors taskbar problem mcphersonline General Discussion 5 01 Feb 2010
with dual monitors my the desktop extends behind the taskbar chapolito Vista General 0 23 May 2009
Problem with dual monitors UserName1 Drivers 0 04 Mar 2009
The Problem with Dual Monitors bretzero Graphic cards 1 30 Dec 2008
Problem with Powerpoint and Dual Monitors Jenander Vista hardware & devices 0 29 Jan 2008
