Annoying CPU load peaks!!!
  1. #1
    maxx Guest
    Hi all,
    i'm running Vista Home Premium and my CPU is periodically used by the
    services LocalSystemNetworkRestricted and Dcomlaunch (svchost), having load
    peaks up to 30% every 6 seconds more or less. This is really annoying since
    they don't allow me write a text without interruptions. Can anybody help me
    please?
    Thanks a lot in advance. Best regards,
  2. #2
    Mr. Arnold Guest
    Re: Annoying CPU load peaks!!!
    "maxx" <maxx@discussions.microsoft.com> wrote in message
    news:A7C84541-C6EB-4CD7-BCE3-AB4DD17BE564@microsoft.com...
    > Hi all,
    > load
    > since
    > me
    > please?
    Why don't you use Process Explorer or some of the other Sysinternals tools
    and go look?
    With PE, you can go to View Menu Show lower pane and Show all DLL(s). It
    will show you all processes running with a process in the lower pane, when
    you click a process in the upper pane. You can right click a process in the
    upper pane, go to Properties and get more information about who or what is
    using something like Svchost.exe, as an example.
    <http://www.pcworld.com/downloads/file/fid,23780-order,1-page,1-c,alldownloads/description.html>
    http://www.microsoft.com/technet/sys...s/default.mspx
  3. #3
    John Barnes Guest
    At 30% it shouldn't be interfering with you doing other tasks. You give no
    information about your system specs, but if dual core you can change
    affinity, and if single core, many svchost functions can be set to a lower
    priority.
    > Hi all,
    > load
    > since
    > me
    > please?
Annoying CPU load peaks!!! problems?
Windows Update Won't Load--gets error-"This page failed to load" sgibbins Windows Updates 7 08 Jun 2009
Does the XMLDocument.Load(System.IO.Stream) method load the whole Shawn Sesna .NET General 1 12 Sep 2008
Annoying CPU load peaks that they don't allow me write any text!! maxx Vista performance & maintenance 0 18 Aug 2007
CPU peaks/Mouse Lag in 5384.4 Jiøí Fiala Vista General 7 03 Jun 2006
CPU peaks in 5384 Jiøí Fiala Vista performance & maintenance 3 26 May 2006
