Vista Ultimate on 64-bit Machine
  1. #1
    rmgalante@galaware.com Guest
    I tried to uninstall Office 2007 Home and Student Trial Version and
    install my Office 2003 Professional edition. I've spent several hours
    trying to configure the system appropriately. I seen some posts that
    said to disable the UAC. But I would rather run the system as it's
    supposed to be configured. Also, I tried removing all the Office
    registry entries with the MS registry configuration tool. That seemed
    to work. Then I installed Office 2003 Professional.
    I installed service pack 1 and service pack 2. Every time I run Word
    or Excel, it tells me that Word or Excel is not installed for the
    current user. So I use system restore to return the system back to
    it's previous state.
    So how do I remove Office 2007 Home and Student Trial Version and
    install Office 2003 Professional so that it will run on Vista?
    By the way, I am logged in as an Admin.
  2. #2
    Re: Vista Ultimate on 64-bit Machine
    I would add to make one more thing. I have successfully installed
    Office 2003 Professional on another machine that is running Windows
    Vista Home Premium. In that case, a trial version of Office 2007 was
    not installed. Also, it's a 32 bit machine.
  3. #3
    John Barnes Guest
    Are you logged on as administrator or user with administrative privileges.
    There should be no problems uninstalling it from the user it was installed
    by, but you may have better luck in safe mode.
    <rmgalante@galaware.com> wrote in message
    news:1187521239.243535.223320@a39g2000hsc.googlegroups.com...
Vista Ultimate on 64-bit Machine problems?
install windows xp or vista ultimate on new machine? jasonli18t General Discussion 17 07 Oct 2008
Cannot activate my Vista Ultimate on new machine dba123 Vista installation & setup 9 02 Mar 2008
Vista Ultimate and running within a virtual machine... andyd Vista installation & setup 10 09 Nov 2007
Vista Home and Ultimate on same machine Iain Vista installation & setup 2 03 Apr 2007
Installing Vista Ultimate on more than one machine.. bigbloke Vista installation & setup 8 06 Feb 2007
