Vista - power options and vista explorer
Old 08-21-2007   #1 (permalink)
seth
i've been working with windows since the days of wfw 3.11 so i'm not a
novice, though still learning about the changes in vista
i had a couple issues maybe someone can help me with
first with sleep (used to be hibernate). the hiberfil.sys file is there and
i want to delete it (save 2gb space; is not used) but can't figure it out
if i go to change advanced power options, i have 'sleep after - never'
'allow hybrid sleep - off' and 'hibernate after - never'
however it doesn't delete the hiberfil.sys file. anyone know why? am i
missing something? it says the file is in use so can't delete manually
second issue is with vista explorer
previously, i was able to customize the explorer view the way i want and
select 'apply to all folders' and every folder would have the same view
i try that in vista and it doesn't work. after i do that, selecting other
folders goes to other views and the columns don't stay.
for example, i will have it with details showing name, date modified, type,
attribute then tell it to apply to all folders.
next, if i select the root of C, it shows as a list; if i change to details,
the columns are name, date taken, tags, size, rating as if it is a pictures
folder.
of course, being the root of the drive, there is no customize tab to specify
file type (pictures, music, etc)
anyone else have the same issue?
Old 08-21-2007   #2 (permalink)
Val
Re: power options and vista explorer
One way to get rid of hiberfil (and turn of hibernation ability) is to do
Disc Cleanup, and there select to remove Hibernation File.
you can easily enable or disable hibernation with the command line command:
powercfg -H on
powercfg -H off
You must run command prompt as an administrator
Val
"seth" <seth@myhouse.org> wrote in message
news:ulEm7xG5HHA.4476@TK2MSFTNGP06.phx.gbl...
folder.
Old 08-22-2007   #3 (permalink)
Quote  Quote: Originally Posted by seth View Post
folder.
Hi Seth,
Val answered your first problem above this.
To make Vista remember you view settings again do all of the "Second Method" section here.
Windows Explorer Folder View settings
To change the folder type template on the "root C:" and to see how to apply it to all the same folder type templates, see this link.
Windows Explorer - Folder Type Templates
This should help with what you needed.
Solved Power Options Corrupt (power plan unavailable) General Discussion
Useful tool for power enthusiasts on the go (advanced power options) General Discussion
Vista - Power Options Vista General
Vista - Power Options Vista security
Power Management/Power Options in Vista Vista General
