| | Help on Restore Previous Versions when I right click on a folder and click "restore previous versions", the box comes up blank. it shows the tabs but not the box where all the files should be. I have tried to find something on the internet and tried a "solution". this was binding the file and sharing protocol to a network connection. |
| Restore Previous Versions - Restore or Remove from Context Menu | Tutorials | |||
| Previous Versions Tab - Restore or Remove from Properties | Tutorials | |||
| Restore Previous Versions menu item missing/hidden? | Vista General | |||
| No previous versions to restore | Vista performance & maintenance | |||
| restore points and previous versions (vss) | Vista General | |||
