| | Shutdown/Restart issue - power stays on OK, so I have a gateway mx6445, that has vista ultimate 32 bit installed. All was great at first... Now, when trying to restart or shutdown, it will go through the whole process fine, but when the screen goes black (when it would normally be off), it is still powered on. Only way to get it to do anything is to hold the power button to force a shut off. I haven't made any big changes with it that could contribute to the new problem. Just regular windows updates. I did read somewhere that someone with a similar system was having the same problem, and it was their display driver (ati radeon on an amd system). I installed new drivers from ati's site, and still no change. Anyone have any suggestions for me? |
| | RE: Shutdown/Restart issue - power stays on When you shut down your computer your monitor should go into power-saving mode; that is the light on it changes from green to orange. But is stays on as orange until you power off at the wall. Check your power saving settings. "Brian" wrote: > OK, so I have a gateway mx6445, that has vista ultimate 32 bit installed. All > was great at first... > Now, when trying to restart or shutdown, it will go through the whole > process fine, but when the screen goes black (when it would normally be off), > it is still powered on. Only way to get it to do anything is to hold the > power button to force a shut off. > > I haven't made any big changes with it that could contribute to the new > problem. Just regular windows updates. I did read somewhere that someone with > a similar system was having the same problem, and it was their display driver > (ati radeon on an amd system). I installed new drivers from ati's site, and > still no change. > > Anyone have any suggestions for me? |
| | RE: Shutdown/Restart issue - power stays on My bad - forgot to specify that it's a laptop. When I say it stays on, the light in the power button stays lit, as well as one of the led lights by the mousepad (it looks to be some sort of wireless type indicator but I can turn it off using the function key along with F2 or one of those - don't have the laptop with me currently to verify...) The led, to try to describe it, looks something like this: (((.))) but the . is actually a rather large circle in the center. Here's a link to the system's specs, if it is of any help. http://support.gateway.com/s/Mobile/...09110sp2.shtml Thanks again. "Mick Murphy" wrote: > When you shut down your computer your monitor should go into power-saving > mode; that is the light on it changes from green to orange. But is stays on > as orange until you power off at the wall. Check your power saving settings. > > "Brian" wrote: > > > OK, so I have a gateway mx6445, that has vista ultimate 32 bit installed. All > > was great at first... > > Now, when trying to restart or shutdown, it will go through the whole > > process fine, but when the screen goes black (when it would normally be off), > > it is still powered on. Only way to get it to do anything is to hold the > > power button to force a shut off. > > > > I haven't made any big changes with it that could contribute to the new > > problem. Just regular windows updates. I did read somewhere that someone with > > a similar system was having the same problem, and it was their display driver > > (ati radeon on an amd system). I installed new drivers from ati's site, and > > still no change. > > > > Anyone have any suggestions for me? |
| Vista restart power issue, monitor won't respond. | Vista General | |||
| Shutdown & restart problems | Vista General | |||
| Screen goes black and pc stays on when I shutdown | General Discussion | |||
| Help! My laptop can't restart or shutdown! | Vista General | |||
| No OPtion for shutdown or restart | Vista General | |||
