| | System (PID 4) "eat" the whole memory Some 25% of the switch on times my Dell D620 Vista enterprise laptop hangs after a couple of minutes. Investigation with Process Explorer shows that process System (PID 4) keep 50% of cpu and "eat" the whole memory (2 GB) in a couple of minutes thus freezing the PC. Further investigations shows that the offending thread seems to be the driver ndis.sys which use 50% of the CPU. After one (sometimes two) hard reboot (few seconds on the power switch button) I can use the PC. The PC SW is fully updated. Any suggestion? |
| | Re: System (PID 4) "eat" the whole memory "Riccardo" <Riccardo@nospam.com> wrote... > Some 25% of the switch on times my Dell D620 Vista enterprise laptop hangs > after a couple of minutes. Investigation with Process Explorer shows that > process System (PID 4) keep 50% of cpu and "eat" the whole memory (2 GB) > in a couple of minutes thus freezing the PC. Further investigations shows > that the offending thread seems to be the driver ndis.sys which use 50% of > the CPU. After one (sometimes two) hard reboot (few seconds on the power > switch button) I can use the PC. The PC SW is fully updated. Hi Riccardo, As you have seen, the "System" process (PID 4) is actually the NT Kernel. As such, it is outside the usual user-mode process space, but it's called "System" in Task Manager and some other tools, as a convenient name. NDIS.SYS is obviously the NDIS driver. It is a standard part of Windows, since NT 3.1. NDIS.SYS implements the NDIS layer between the network protocol stack and the Network Card drivers. So you would have TCP/IP above NDIS, and the specific driver for your NIC hardware below NDIS (eg an Intel 82566 Driver, a Broadcom BMC4401 driver, a RealTek RTL816 driver etc): (top of stack) Applications Winsock TDI TCP/IP NDIS NIC Driver Network Card hardware (bottom of stack) NDIS.SYS is some of the most heavily exercised code on the planet - every Windows machine connected to a network hammers this driver continuously. So although it is *possible* there may be a new, undiscovered memory leak or infinite loop in NDIS ... it seems unlikely. It's more likely that something else above or below NDIS, is putting it into a troubled state. A couple of possibilities: - the network card driver you have might not be fully Vista-compatible. Can you tell us what kind of machine you have, and what brand and model network card? - there may be excessive network activity. What you're describing sounds a bit like a denial-of-service attack maybe someone is hammering your network address with half-closed TCP/IP sessions, or just a packet storm which is causing a large number of Interrupts. If you are on a corporate LAN, check with your network guys to see if there is any abnormal network activity. Or, while the machine is in the problem state, go to a command prompt and run a command like "netstat -ano" to see if there are an unusually large number of network sessions active. Alternatively, run Task Manager, go to the Network tab and watch the network utilisation. If NDIS is maxed out, it is possible the network utilisation will be very high. If it is not an outside attack, you may be infected with a bot or rootkit, which is generating a lot of outbound network traffic, so run an antivirus and anti-spyware tool as well. Or maybe some app on the machine is hammering the network as part of its normal operations (database synchronisation, etc). Other folks may have extra ideas for you; hope this helps a bit, -- Andrew McLaren amclar (at) optusnet dot com dot au |
| | Re: System (PID 4) "eat" the whole memory Thank you Andrew for your suggestions, at least now I know where I should look. My network adapter are "Broadcom NetXtreme 57xx Gigabit Controller" and "Intel PRO/Wireless 3945ABG Network connection" but I got the freezing problem without any connection to the net (phisical cable or WiFi). Actually my suspect is now on ntkrnlpa.exe thread which, during the freezing process, get the highest value (> 1000) in CSwitch Delta of System:4 properties in Process explorer. Ciao, Riccardo "Andrew McLaren" <andrew@fakeaddress.com> wrote in message news:888E973D-B3A5-436A-A583-5CB0D5ABC497@microsoft.com... > "Riccardo" <Riccardo@nospam.com> wrote... >> Some 25% of the switch on times my Dell D620 Vista enterprise laptop >> hangs after a couple of minutes. Investigation with Process Explorer >> shows that process System (PID 4) keep 50% of cpu and "eat" the whole >> memory (2 GB) in a couple of minutes thus freezing the PC. Further >> investigations shows that the offending thread seems to be the driver >> ndis.sys which use 50% of the CPU. After one (sometimes two) hard reboot >> (few seconds on the power switch button) I can use the PC. The PC SW is >> fully updated. > > Hi Riccardo, > > As you have seen, the "System" process (PID 4) is actually the NT Kernel. > As such, it is outside the usual user-mode process space, but it's called > "System" in Task Manager and some other tools, as a convenient name. > > NDIS.SYS is obviously the NDIS driver. It is a standard part of Windows, > since NT 3.1. NDIS.SYS implements the NDIS layer between the network > protocol stack and the Network Card drivers. So you would have TCP/IP > above NDIS, and the specific driver for your NIC hardware below NDIS (eg > an Intel 82566 Driver, a Broadcom BMC4401 driver, a RealTek RTL816 driver > etc): > > (top of stack) > Applications > Winsock > TDI > TCP/IP > NDIS > NIC Driver > Network Card hardware > (bottom of stack) > > NDIS.SYS is some of the most heavily exercised code on the planet - every > Windows machine connected to a network hammers this driver continuously. > So although it is *possible* there may be a new, undiscovered memory leak > or infinite loop in NDIS ... it seems unlikely. It's more likely that > something else above or below NDIS, is putting it into a troubled state. A > couple of possibilities: > > - the network card driver you have might not be fully Vista-compatible. > Can you tell us what kind of machine you have, and what brand and model > network card? > > - there may be excessive network activity. What you're describing sounds a > bit like a denial-of-service attack maybe someone is hammering your > network address with half-closed TCP/IP sessions, or just a packet storm > which is causing a large number of Interrupts. If you are on a corporate > LAN, check with your network guys to see if there is any abnormal network > activity. Or, while the machine is in the problem state, go to a command > prompt and run a command like "netstat -ano" to see if there are an > unusually large number of network sessions active. Alternatively, run Task > Manager, go to the Network tab and watch the network utilisation. If NDIS > is maxed out, it is possible the network utilisation will be very high. If > it is not an outside attack, you may be infected with a bot or rootkit, > which is generating a lot of outbound network traffic, so run an antivirus > and anti-spyware tool as well. Or maybe some app on the machine is > hammering the network as part of its normal operations (database > synchronisation, etc). > > Other folks may have extra ideas for you; hope this helps a bit, > -- > Andrew McLaren > amclar (at) optusnet dot com dot au > |
| | Re: System (PID 4) "eat" the whole memory Andrew McLaren andrew@fakeaddress.com posted to microsoft.public.windows.vista.general: > "Riccardo" <Riccardo@nospam.com> wrote... >> Some 25% of the switch on times my Dell D620 Vista enterprise >> laptop hangs after a couple of minutes. Investigation with Process >> Explorer shows that process System (PID 4) keep 50% of cpu and >> "eat" the whole memory (2 GB) in a couple of minutes thus freezing >> the PC. Further investigations shows that the offending thread >> seems to be the driver ndis.sys which use 50% of the CPU. After one >> (sometimes two) hard reboot (few seconds on the power switch >> button) I can use the PC. The PC SW is fully updated. > > Hi Riccardo, > > As you have seen, the "System" process (PID 4) is actually the NT > Kernel. As such, it is outside the usual user-mode process space, > but it's called "System" in Task Manager and some other tools, as a > convenient name. > > NDIS.SYS is obviously the NDIS driver. It is a standard part of > Windows, since NT 3.1. NDIS.SYS implements the NDIS layer between > the network protocol stack and the Network Card drivers. So you > would have TCP/IP above NDIS, and the specific driver for your NIC > hardware below NDIS (eg an Intel 82566 Driver, a Broadcom BMC4401 > driver, a RealTek RTL816 driver etc): > > (top of stack) > Applications > Winsock > TDI > TCP/IP > NDIS > NIC Driver > Network Card hardware > (bottom of stack) > > NDIS.SYS is some of the most heavily exercised code on the planet - > every Windows machine connected to a network hammers this driver > continuously. So although it is *possible* there may be a new, > undiscovered memory leak or infinite loop in NDIS ... it seems > unlikely. It's more likely that something else above or below NDIS, > is putting it into a troubled state. A couple of possibilities: > > - the network card driver you have might not be fully > Vista-compatible. Can you tell us what kind of machine you have, and > what brand and model network card? > > - there may be excessive network activity. What you're describing > sounds a bit like a denial-of-service attack maybe someone is > hammering your network address with half-closed TCP/IP sessions, or > just a packet storm which is causing a large number of Interrupts. > If you are on a corporate LAN, check with your network guys to see > if there is any abnormal network activity. Or, while the machine is > in the problem state, go to a command prompt and run a command like > "netstat -ano" to see if there are an unusually large number of > network sessions active. Alternatively, run Task Manager, go to the > Network tab and watch the network utilisation. If NDIS is maxed out, > it is possible the network utilisation will be very high. If it is > not an outside attack, you may be infected with a bot or rootkit, > which is generating a lot of outbound network traffic, so run an > antivirus and anti-spyware tool as well. Or maybe some app on the > machine is hammering the network as part of its normal operations > (database synchronisation, etc). > > Other folks may have extra ideas for you; hope this helps a bit, Much agreed, also try SFC, your ndis driver level may have been corrupted. |
| | Re: System (PID 4) "eat" the whole memory Thak you, no integrity violation spotted by SFC. (Un)Fortunately I don't get any more freezing so no much debug, my best bet is now on some bug on disk sharing without any net connection. Ciao, Riccardo <quiettechblue@yahoo.com> wrote in message news:eM6U5H35HHA.5316@TK2MSFTNGP04.phx.gbl... > > Much agreed, also try SFC, your ndis driver level may have been > corrupted. |
| | #6 (permalink) |
| | Re: System (PID 4) "eat" the whole memory "Riccardo" <Riccardo@nospam.com> wrote in message news:%23pWzsSw5HHA.5268@TK2MSFTNGP02.phx.gbl... > Thank you Andrew for your suggestions, at least now I know where I should > look. My network adapter are "Broadcom NetXtreme 57xx Gigabit Controller" > and "Intel PRO/Wireless 3945ABG Network connection" but I got the freezing > problem without any connection to the net (phisical cable or WiFi). > Actually my suspect is now on ntkrnlpa.exe thread which, during the > freezing process, get the highest value (> 1000) in CSwitch Delta of > System:4 properties in Process explorer. A high CSwitch dfelta would indicate a high rate of context switched - so the thread is very busy - could indicate a high number fo interrupts or else some very active thread in the kernel. Unfortunately, I don't recognise it as a "well-known" problem in Vista - I think you'll just have to keep debugging and investigating. If it was my machine I'd try booting in safe mode to see if same problem occurs; and possibly also toggle ACPI support or a few other settings to see if they are relevant. But it's pretty hide-and-seek stuff ... Good luck with it! -- Andrew McLaren amclar (at) optusnet dot com dot au |
| | #7 (permalink) |
| | Re: System (PID 4) "eat" the whole memory Hi Riccardo, I can tell you that I am experiencing the exact same problem. Had it for a few weeks now on a rarely used Core2Duo HP NC8430 laptop running Vista Ultimate. Its made worse by being an intermittent problem. Do you experience that as well, or do you have it on every boot? I have just started working through the troubleshooting and will post my result here when/if I get any wiser on this. regards Lars -- Larswa ------------------------------------------------------------------------ Larswa's Profile: http://forums.techarena.in/member.php?userid=30022 View this thread: http://forums.techarena.in/showthread.php?t=807657 http://forums.techarena.in |
| | #8 (permalink) |
| | Re: System (PID 4) "eat" the whole memory Yeah ... I nailed it. I had the same two NIC's installed on my laptop as you did, and I could boot into safe mode (with network) and they worked every time. When not in safe mode, I got the problem 8/10 times or so it seems. So I booted into safe mode ... disables all NIC's. The builtin plus my two VMWare virtual NIC's, and the problem went away. Permanently. Then I started enabling one NIC after the other ... and rebooted a couple times after each re-enabling. It turns out that it was the wireless NIC that caused the problem, so back into safe mode, where I deleted the NIC. Answered yes to removing the driver. Vista instantly discovered the NIC again, and reinstalled the drivers. Since then (5 reboots) I havent been able to recreate the problem. Sweeeeet. ![]() Hope that helps someone with a similar problem. regards Lars -- Larswa ------------------------------------------------------------------------ Larswa's Profile: http://forums.techarena.in/member.php?userid=30022 View this thread: http://forums.techarena.in/showthread.php?t=807657 http://forums.techarena.in |
| | #9 (permalink) |
| | Re: System (PID 4) "eat" the whole memory Hmm .. It was too early to celebrate. It definitely was the NIC, but after removing it and letting it reinstall, and a few restarts later .. the problem is back. Disabling the NIC fixes it. But I can't seem to uninstall it completely. Annoying. -- Larswa ------------------------------------------------------------------------ Larswa's Profile: http://forums.techarena.in/member.php?userid=30022 View this thread: http://forums.techarena.in/showthread.php?t=807657 http://forums.techarena.in |
| | #10 (permalink) |
| | Re: System (PID 4) "eat" the whole memory Just for the record, it looks like it was due to the presence of two network drives in absence of any network connections. I removed the net drives and everything looks fine (although with little statistic). Riccardo "Riccardo" <Riccardo@xxxxxx> wrote in message news:e2xadQ75HHA.1148@xxxxxx Quote: > Thak you, no integrity violation spotted by SFC. (Un)Fortunately I don't > get any more freezing so no much debug, my best bet is now on some bug on > disk sharing without any net connection. > Ciao, > Riccardo > > > <quiettechblue@xxxxxx> wrote in message > news:eM6U5H35HHA.5316@xxxxxx Quote: >> >> Much agreed, also try SFC, your ndis driver level may have been >> corrupted. |
| "System Restore" NEVER "Restores" | General Discussion | |||
| "Extensible Authentication Protocol" service gives "The system cannot find the file specified" error | Vista networking & sharing | |||
| What do "Windows Update" and "system restore" have in common? | Vista General | |||
| Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" | Vista General | |||
| Error: "Cannot convert "System.Object[]" to "System.Int32"." | PowerShell | |||
