Vista - Dial-up Problem
Old 08-25-2007   #1 (permalink)
Hsherman
Dial-up Problem
Vista Home Premium 32 bit; Celeron 2.8; IE-7: Windows Mail
Am having a problem with dial-up. In the dial-up Connect window, I check
"Save Username and password" and set it to "Anyone who uses this computer",
and connect successfully. But the next time I try to connect, the checkbox
is cleared and I have to reset it. If I don't do this, the connection
either fails with Error 691 on "Verifying Username and password", or if it
connects, it randomlly disconnects while trying to read mail or surfing web.
(In this case, Network and Sharing Center reverts to "Local Only" for
Internet Connection). I have tried all the obvious options with no success.
This problem just surfaced a few weeks ago; I suspect it may have been
caused by one of the Updates.
Am I missing something in the options or is a registry hack needed? One
other thing: In properties, both IPv4 and IPv6 are installed. Could this
problem be related to IPv6?
Old 08-25-2007   #2 (permalink)
John Barnett MVP
Re: Dial-up Problem
Hsherman, I bugged this problem during the early beta of Vista and was told
that the 'save password' option was disabled by default. My machine displays
the user name, but the password box is blank until I type in the password.
Unfortunately, I too have the same problem with user name and password
which, obviously to both of use, is a pain in the butt. I can't say that I
have any connection problems though. My DSL modem connects regardless of
whether the user name and password option is checked or not (well assuming I
put the password in, of course).
John Barnett MVP
Associate Expert
Windows - Shell/User
Web: http://xphelpandsupport.mvps.org
Web: http://vistasupport.mvps.org
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
"Hsherman" <sherhar@westelcom.com> wrote in message
news:%23jrlAew5HHA.464@TK2MSFTNGP02.phx.gbl...
> computer", and connect successfully. But the next time I try to connect,
> the checkbox is cleared and I have to reset it. If I don't do this, the
> connection either fails with Error 691 on "Verifying Username and
> password", or if it connects, it randomlly disconnects while trying to
> read mail or surfing web. (In this case, Network and Sharing Center
> reverts to "Local Only" for Internet Connection). I have tried all the
> obvious options with no success. This problem just surfaced a few weeks
> ago; I suspect it may have been caused by one of the Updates.
Old 09-29-2007   #3 (permalink)
Hsherman
Re: Dial-up Problem
OK, I seem to have solved my problem by checking "Connect Automatically" in
the
inital dialup window. Vista remembers this setting, bypasses the second
dialup window and connects without any of the problems outlined below. Like
others,
I have always been wary of allowing programs to connect to the internet
automatically,
but in this case it seems to be the only way. Any ideas as to why Vista
will remember
the settings in one case and not the other?
"Hsherman" <sherhar@xxxxxx> wrote in message
news:%23jrlAew5HHA.464@xxxxxx
Problem With Dial Up Connection Vista General
2 Dial-up Connections - Problem Vista mail
Internet dial up problem Vista General
dial up problem Network & Sharing
Problem with dial-up modem... Vista General
