| Guest | Hard drive management - extend I have one physical hard drive which came delivered with my Dell computer. The D drive is 10 GB and I would like to double that. When I right click on that drive (in Computer Management Console \ Storage), the Extend option is grayed out. I thought, OK, maybe I first have to Shrink the size of Drive C (228 GB) and then the option to Extend Drive D will be available. That didn't work. Suggestions? |
| Guest | Re: Hard drive management - extend Your D drive is a factory Restore Partition provided by Dell to recover your computer to a factory shipped condition and should not be used for anything else. If you made recovery DVDs, or order them from Dell, you can delete the partition and extend C to take up the recovered space. Or you can shrink C (although you might have limited success with this because of the page file) and create a larger D volume. I believe D cannot be extended as it is now because it is not NTSF formatted, -- I Bleed Blue and Gold GO BEARS! "Dave Horne" <dave.horne@home.nl> wrote in message news:u9C5Twy5HHA.5740@TK2MSFTNGP04.phx.gbl... >I have one physical hard drive which came delivered with my Dell computer. The >D drive is 10 GB and I would like to double that. > > When I right click on that drive (in Computer Management Console \ Storage), > the Extend option is grayed out. > > I thought, OK, maybe I first have to Shrink the size of Drive C (228 GB) and > then the option to Extend Drive D will be available. > > That didn't work. Suggestions? |
| Guest | Re: Hard drive management - extend Gentlemen, thanks to both of you for your answers. I will leave Drive D alone ... I can't extend it even by first reducing Drive C. The only reason for extending Dive D, the weekly backups to Drive D fail after a few weeks since there's not enough room. I wind up deleting the backup files and doing a total backup. I realize if Drive fails, Drive D fails with it. I was just hoping to have an easy solution to extend Drive D. I'll post at the Dell forum and see what Dell suggests ... thopugh I expect to hear the same that you guys suggested. Thanks, Dave Horne |
| Disk Management - Delete and Extend | Tutorials | |||
| Extend C:Drive | Vista account administration | |||
| Extend C: Drive | Vista General | |||
| I deleted my hard drive in disk management now i cant allocate it | General Discussion | |||
| why extend option in disk management is gray? | Vista General | |||
