| | System restore not working! I tried to restore my computer to an earlier state but after it does everything and restarts i get the message "system restore has encountered a problem. no changes were made to your computer" it says the reason is "unknown error" does anyone else have this in Vista? |
| | Re: System restore not working! "wrathofpaulii" <wrathofpaulii@xxxxxx> wrote in message news:0DFDF510-D881-4465-BB1A-F1EF2F1311C5@xxxxxx Quote: > I tried to restore my computer to an earlier state but after it does > everything and restarts i get the message "system restore has encountered Quote: > problem. no changes were made to your computer" it says the reason is > "unknown error" does anyone else have this in Vista? run some H/W diagnostics such as the mfg's HD test utility and a good RAM test |
| | Re: System restore not working! Hi, Are there any Norton applications installed? If so read this. "Restoration Incomplete. Your computer cannot be restored . . . " http://bertk.mvps.org/html/symantecdoc1.html Another option is to run System Restore from System Recovery Options: http://bertk.mvps.org/html/recovery.html Regards, Bert Kinney MS-MVP Shell/User http://bertk.mvps.org Member: http://dts-l.org wrathofpaulii wrote: Quote: > I tried to restore my computer to an earlier state but after it does > everything and restarts i get the message "system restore has encountered a > problem. no changes were made to your computer" it says the reason is > "unknown error" does anyone else have this in Vista? |
| | Re: System restore not working! "wrathofpaulii" <wrathofpaulii@xxxxxx> wrote in message news:0DFDF510-D881-4465-BB1A-F1EF2F1311C5@xxxxxx Quote: >I tried to restore my computer to an earlier state but after it does > everything and restarts i get the message "system restore has encountered > a > problem. no changes were made to your computer" it says the reason is > "unknown error" does anyone else have this in Vista? Are you dual booting XP and Vista? Lang |
| | RE: System restore not working! system restore will not restore if you are running any norton anti virus you must disable it first this may be applicable to other security software also but can't be sure on that as i run norton -- martyb "wrathofpaulii" wrote: Quote: > I tried to restore my computer to an earlier state but after it does > everything and restarts i get the message "system restore has encountered a > problem. no changes were made to your computer" it says the reason is > "unknown error" does anyone else have this in Vista? |
| | #6 (permalink) |
| | RE: System restore not working! it happened to me too, it's really giving me a headache not only this it also give problem from using excel 2007, did you resolve the problem yet? "wrathofpaulii" wrote: Quote: > I tried to restore my computer to an earlier state but after it does > everything and restarts i get the message "system restore has encountered a > problem. no changes were made to your computer" it says the reason is > "unknown error" does anyone else have this in Vista? |
| | #7 (permalink) |
| | RE: System restore not working! I thought that too, but even after turning all norton services off, still have the same problem. Something in systm restore seems corrupted. Probably need to fix with vista repair disk? "marty" wrote: Quote: > system restore will not restore if you are running any norton anti virus you > must disable it first this may be applicable to other security software also > but can't be sure on that as i run norton > -- > martyb > > > "wrathofpaulii" wrote: > Quote: > > I tried to restore my computer to an earlier state but after it does > > everything and restarts i get the message "system restore has encountered a > > problem. no changes were made to your computer" it says the reason is > > "unknown error" does anyone else have this in Vista? |
| | #8 (permalink) |
| | RE: System restore not working! I'm having his problem too for the first time. Always worked on my windows xp, but it is not working on Vista. Is there a definitive answer on this? Is it really Norton related? "wrathofpaulii" wrote: Quote: > I tried to restore my computer to an earlier state but after it does > everything and restarts i get the message "system restore has encountered a > problem. no changes were made to your computer" it says the reason is > "unknown error" does anyone else have this in Vista? |
| | #9 (permalink) |
| | RE: System restore not working! I tried all the sugguested norton fixes, still have the problem. I have also retried enough times to where I am no longer albe to select a restore point that worked. I have System Mechanic 7.5 installed, and wonder if this is the cause of the problem. It compresses and backs up both the registry and hive. I'm beginning to think about I may need to do a systems restore repair repair from the Vista DVD. What do you think? Thanks, the photo guy. "Gerry" wrote: Quote: > I'm having his problem too for the first time. Always worked on my windows > xp, but it is not working on Vista. Is there a definitive answer on this? > Is it really Norton related? > > "wrathofpaulii" wrote: > Quote: > > I tried to restore my computer to an earlier state but after it does > > everything and restarts i get the message "system restore has encountered a > > problem. no changes were made to your computer" it says the reason is > > "unknown error" does anyone else have this in Vista? |
| | #10 (permalink) |
| | Re: System restore not working! "Photo guy" <Photoguy@xxxxxx> wrote in message news:8DD1EE72-A1C1-469B-8B19-0C13FE76851E@xxxxxx Quote: >I tried all the sugguested norton fixes, still have the problem. I have >also > retried enough times to where I am no longer albe to select a restore > point > that worked. > firewall options/turn on protection for my Sym Product" in NIS2007. Before it was turned off, any restore point attempt failed. Ron |
| System restore not working | Vista performance & maintenance | |||
| System Restore not working | Vista General | |||
| System Restore Not Working | Vista General | |||
| System Restore not working | Vista security | |||
