Vista - weird problem
Old 08-27-2007   #1 (permalink)
james
weird problem
I'm having a weird problem that I can't solve. When I click to go into my
control panel and click the sound icon. I then click on the icon to access my
microphone but the window freezes up and I can only close it by going into
the task manager. I really need to turn my microphone on. is there anything I
can do?
Old 08-27-2007   #2 (permalink)
Spirit
Re: weird problem
With the Mic plugged in go into Device Manager and remove it
(look in sounds) and the rest of the sound card. Reboot, be
prepared re-install your audio drivers.... good time to go look
for the latest drivers before you do this. When your reboot
the sound card and rest will be re-installed.
"james" <james@xxxxxx> wrote in message news:847E2312-73B5-4450-AC5A-627A90E1DFDA@xxxxxx
> can do?
Old 08-27-2007   #3 (permalink)
james
Re: weird problem
i thank you for that. my mic is now working but that window steal freezes up
> > can do?
Weird - Very weird annoying problem General Discussion
Weird ICS problem Vista networking & sharing
weird problem Vista mail
weird problem Vista General
weird problem Vista performance & maintenance
