Vista - Icon border changes but picture on icon stays the same when enlarg
Old 08-28-2007   #1 (permalink)
Brazos
I do not have many icons on my desktop and I like my icons larger. When I
enlarge them the icon border changes but the picture on the icon stays the
same size. What is going on here?
Old 08-28-2007   #2 (permalink)
Re: Icon border changes but picture on icon stays the same when enlarg
Quote  Quote: Originally Posted by Brazos View Post
Hi Brazos,
In order to see the icon enlarge past the "Medium" size, they need to be a 256 bit .ico (Icon) file. Some older programs and icons in Vista meant for other display modes are not 256 bit. Most of the good icons in Vista are located here: "C:\Windows\System32\imageres.dll" . Just open this file with the "Change Icon" button. See this for more details on how to change the icons.
Shortcut Folder or File Icon Change
Old 08-28-2007   #3 (permalink)
Mary
RE: Icon border changes but picture on icon stays the same when enlarg
How are you enlarging them? Right click on the Desktop, View, select Large
Icons or Extra Lg.
Old 08-28-2007   #4 (permalink)
Brazos
I use the right click method and the control and mouse wheel method.
Old 08-29-2007   #5 (permalink)
Brazos
brink is a 256 bit icon an icon that is 256x256 in size? If that it is then
that is what I am using.
Old 08-29-2007   #6 (permalink)
Sorry Brazos,
It is 256x256 pixels, but 32 bit. You can read more on the icons here. It will show you how to make icons that are compatible with the larger sizes. You might be able to convert the ones you have to.
Vista Icons - Introducing Vista Icons - How to create Vista Icons
Old 08-29-2007   #7 (permalink)
Brazos
I had downloaded Microangeleo toolset 6 and was using their icon editor. I
took your advice and downloaded Axialis icon editor. This worked great. It
is a very good program. I want to extend my thanks to you. Made my day man.
Old 08-29-2007   #8 (permalink)
Your welcome Brazos,
I always found Axialis pretty easy to use and understand. Glad that it helped you out.
Thank you for the feedback,
Desktop icon picture preview Microsoft Office
Picture icon preview in browser General Discussion
User Folder Icon Picture General Discussion
Tray icon stays after exiting msn Live Messenger
