Vista - Problem after Vista SP1 Pre-Beta
Old 08-29-2007   #1 (permalink)
VanillaTbone
I have installed the Vista SP1 Pre-Beta(Build 6001.16633) and after I
restarted I have the windows version info displayed at the lower right-hand
side of my screen. This is no problem, but the problem is that it is showing
my Vista as an "evaluation copy". I am using Vista Home-Premium on my Toshiba
Satellite A105-S4397 and my Product-Key and Activation are valid.
Screenshot below:
http://tinypic.com/view.php?pic=4t5vgwm
All help is appreciated.
Old 08-29-2007   #2 (permalink)
David A. Spicer
Re: Problem after Vista SP1 Pre-Beta
What were you expecting when you installed a non-supported pre-beta build?
Look for an uninstall/restore point.
No man is an island, but then no man is a potato salad either.
"VanillaTbone" <VanillaTbone@xxxxxx> wrote in message
news:C0C02583-E2BA-44E3-9216-D006B6131BBB@xxxxxx
> right-hand
> showing
> Toshiba
> Screenshot below:
Old 08-29-2007   #3 (permalink)
VanillaTbone
Well, I was wondering if there was a way just to fix the said issue in
general. My laptop is running faster and has had no problems or compatibility
problems at all.
The strange thing is that my laptop has been restarted at least 4 times
since the SP1 install(Sunday). This showed up about 12am EST on Wednesday and
I just thought of it a little strange.
Well, I guess it will stay as it is for now... Even though I created a
restore point right before the update. :P
Old 08-29-2007   #4 (permalink)
SAM-R
6.0.6001.16633 has a time bomb in it. If you check Winver, it will tell you
when your copy of Vista will stop working.
> right-hand
> showing
> Toshiba
> Screenshot below:
Old 08-29-2007   #5 (permalink)
Kerry Brown
You should report this through the proper channels set up in the beta
program. Most people on this newsgroup do not have access to this and if
they do probably can't talk about it.
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
> right-hand
> showing
> Toshiba
> Screenshot below:
Vista Beta 2 DNS Problem Vista networking & sharing
Backup problem in vista Beta 2 Vista General
Vista Beta 2 install problem Vista installation & setup
problem installing Vista Beta 2 Vista General
Vista Beta 2 and IE7 problem Vista General
