Vista - Dual Monitor Display Problem
Old 08-29-2007   #1 (permalink)
Shabacca
After today’s windows update, only one of my dual monitors works. I checked
the display panel and it doesn’t recognize the 2nd monitor. I did a systems
restore to eliminate the update, but my 2nd monitor still isn’t recognized.
Both monitors are connected properly. MY OS is Windows Home Premium and my
Graphics card is a NVIDA 7900 GForce GS. Can someone please help?
Old 08-29-2007   #2 (permalink)
Synapse Syndrome
Re: Dual Monitor Display Problem
"Shabacca" <Shabacca@xxxxxx> wrote in message
news:E0D2744C-0199-423F-BFD4-F99823A5941D@xxxxxx
Quote:
> After today's windows update, only one of my dual monitors works. I
> checked
> the display panel and it doesn't recognize the 2nd monitor. I did a
> systems
> restore to eliminate the update, but my 2nd monitor still isn't
> recognized.
> my
Can you not enable the second monitor in the Settings tab of Display
Properties in Control Panel?
ss.
Old 08-29-2007   #3 (permalink)
Michael Solomon
> checked
> systems
> recognized.
> my
First, check the nVidia website to be sure you have the latest Vista
compatible drivers for the card. Second, reinstall the drivers. NOTE: this
may require first removing the drivers before reinstalling them.
Michael Solomon
Backup is a PC user's best friend
DTS-L.Org: http://www.dts-l.org/
Old 10-16-2007   #4 (permalink)
g
RE: Dual Monitor Display Problem
I have the same problem! It has to be one of the windows updates, because
I've done several clean installs of Vista home premium and it works fine
along with the latest drivers installed. Then once I update the second
monitor disappears. In display settings it only shows one monitor. In
device manager, however, it shows two monitors.
I hope someone has a solution! I've been looking for this for awhile.
Old 12-29-2007   #5 (permalink)
DuaneBS
Hmmm.... I just set up my new machine running two 22" widescreens off of an
NVidia 8800 card... After I installed my Windows updates and restarted my PC,
one of my displays had dissapeared... Both the NVidia control panel and
Windows Display Settings show one monitor enabled, and when I try to enable
the other, it gives me the prompt about keeping changes. After accepting,
nothing changes and my settings are reverted back. This is a strange issue,
but at least I know I'm not the only one now. Did any of you find a fix yet?
Vista logon changes Dual monitor display settings Vista General
Dual monitor display settings revert on startup Vista General
Dual Monitor Display Vista General
When display sleeps it forgets dual monitor setup? Vista hardware & devices
VGA Monitor and S-Video Dual Display Vista hardware & devices
