Vista - Indexed search does not work
Old 08-30-2007   #1 (permalink)
Ron
The Vista search does not work for indexed locations. If I search all
locations it does. If I search for a simple letter such as the letter "a" it
finds nothing. If I go into Advanced Search" and do the same with any
selection BUT "Indexed Search" it finds everything with the letter "a" as it
should. Can anyone help in this matter?
Old 08-30-2007   #2 (permalink)
Re: Indexed search does not work
Quote  Quote: Originally Posted by Ron View Post
Hi Ron,
The Index only searches in specific locations that where added to it other than the default locations to. You can see how to add locations or file types to the index here. You may also want to do Rebuild the index.
Indexing Options
If you want to search everything, then you need to use the non-indexed search.
Desktop Search-Outlook not in indexed locations Microsoft Office
Vista Indexed Search was reset Vista file management
Search nag in Win Explorer w/ non-indexed areas Vista file management
tags aren't indexed in start menu search.... Vista music pictures video
Questions about indexed search options Vista General
