| | Does Overclocking YOur CPU cause problems with your activation? I overclocked my cpu this morning and it worked great but then I noticed in the taskbar something about volume activation failed or something like that - I did not see it until the system was shutting down. I re-booted, turned off the overclocking and after Windows booted I checked the computer properties - everything seems okay and my operating system is still activated. It is truly a sad day if overclocking your cpu causes your activation to fail. Al |
| | Re: Does Overclocking YOur CPU cause problems with your activation? "Alfred Kaufmann" <al_kaufmann@xxxxxx> wrote in message news:8v6gd3laffjiu65alqofefc7josr53mpi8@xxxxxx Quote: >I overclocked my cpu this morning and it worked great but then I > noticed in the taskbar something about volume activation failed or > something like that - I did not see it until the system was shutting > down. I re-booted, turned off the overclocking and after Windows > booted I checked the computer properties - everything seems okay and > my operating system is still activated. > > It is truly a sad day if overclocking your cpu causes your activation > to fail. Even if the system appears to be stable there is a small chance it will still do something odd (there is even if you don't over clock but its much less) and there is little checking done by desktop PCs that will catch it, servers have things like parity/ecc that may catch odd things before anything serious like corrupted data happens. Having said that you probably misread something and it was fine being over clocked. You can over clock it again if you want but make sure you have a backup, M$ aren't going to care if you over clock it.. |
| | Re: Does Overclocking YOur CPU cause problems with your activation? Overclocking has NO effect on activation. Try again and see what happens. My system is overclocked and I did it AFTER I installed Vista U, NO PROBLEMS. D "Alfred Kaufmann" <al_kaufmann@xxxxxx> wrote in message news:8v6gd3laffjiu65alqofefc7josr53mpi8@xxxxxx Quote: >I overclocked my cpu this morning and it worked great but then I > noticed in the taskbar something about volume activation failed or > something like that - I did not see it until the system was shutting > down. I re-booted, turned off the overclocking and after Windows > booted I checked the computer properties - everything seems okay and > my operating system is still activated. > > It is truly a sad day if overclocking your cpu causes your activation > to fail. > > Al > |
| | Re: Does Overclocking YOur CPU cause problems with your activation? On Fri, 31 Aug 2007 15:02:19 +0100, "dennis@xxxxxx" <dennis@xxxxxx-ass.net> wrote: Quote: > >"Alfred Kaufmann" <al_kaufmann@xxxxxx> wrote in message >news:8v6gd3laffjiu65alqofefc7josr53mpi8@xxxxxx Quote: >>I overclocked my cpu this morning and it worked great but then I >> noticed in the taskbar something about volume activation failed or >> something like that - I did not see it until the system was shutting >> down. I re-booted, turned off the overclocking and after Windows >> booted I checked the computer properties - everything seems okay and >> my operating system is still activated. >> >> It is truly a sad day if overclocking your cpu causes your activation >> to fail. >If you over clock then results are unpredictable. >Even if the system appears to be stable there is a small chance it will >still do something odd (there is even if you don't over clock but its much >less) and there is little checking done by desktop PCs that will catch it, >servers have things like parity/ecc that may catch odd things before >anything serious like corrupted data happens. the pitfalls. Quote: >Having said that you probably misread something and it was fine being over >clocked. >You can over clock it again if you want but make sure you have a backup, M$ >aren't going to care if you over clock it.. disappeared. I don't know how M$ activation checks your system but I had 2 days to call M$ when I just changed a video card. If something like that happens everytime I change the cpu/memory speed then it is going to be a real pain. Al |
| | Re: Does Overclocking YOur CPU cause problems with your activation? ram shouldn't affect your ram in this way only overclock, i had mine overclock from a 400mhz to 550mhz and it was fine but like she or he said(sorry i read quickly didn't notice) some pc aren't happy being overclock, and overclocking something will make them wear faster than normal, although tey might last long they're life span is being shorten slowly at a time, just imagine making your granpa run the maraton untill he dies, he won't last long unless she was healthy and strong during his whole life "Alfred Kaufmann" <al_kaufmann@xxxxxx> wrote in message news:8v6gd3laffjiu65alqofefc7josr53mpi8@xxxxxx Quote: >I overclocked my cpu this morning and it worked great but then I > noticed in the taskbar something about volume activation failed or > something like that - I did not see it until the system was shutting > down. I re-booted, turned off the overclocking and after Windows > booted I checked the computer properties - everything seems okay and > my operating system is still activated. > > It is truly a sad day if overclocking your cpu causes your activation > to fail. > > Al > |
| | #6 (permalink) |
| | Re: Does Overclocking YOur CPU cause problems with your activation? I have overclocked it again and noticed no problems. :-) Al On Fri, 31 Aug 2007 10:04:43 -0400, "-Draino-" <guest@xxxxxx> wrote: Quote: >Overclocking has NO effect on activation. > >Try again and see what happens. My system is overclocked and I did it AFTER >I installed Vista U, NO PROBLEMS. > > >D > > >"Alfred Kaufmann" <al_kaufmann@xxxxxx> wrote in message >news:8v6gd3laffjiu65alqofefc7josr53mpi8@xxxxxx Quote: >>I overclocked my cpu this morning and it worked great but then I >> noticed in the taskbar something about volume activation failed or >> something like that - I did not see it until the system was shutting >> down. I re-booted, turned off the overclocking and after Windows >> booted I checked the computer properties - everything seems okay and >> my operating system is still activated. >> >> It is truly a sad day if overclocking your cpu causes your activation >> to fail. >> >> Al >> |
| | #7 (permalink) |
| | Re: Does Overclocking YOur CPU cause problems with your activation? I had no activation issues with may overclock Core2 4300 and Windows Vista Home Premium. I've overclocked it from 1.8 GHz to 3.0 GHz. George On Aug 31, 8:53 am, Alfred Kaufmann <al_kaufm...@xxxxxx> wrote: Quote: > I overclocked my cpu this morning and it worked great but then I > noticed in the taskbar something about volume activation failed or > something like that - I did not see it until the system was shutting > down. I re-booted, turned off the overclocking and after Windows > booted I checked the computer properties - everything seems okay and > my operating system is still activated. > > It is truly a sad day if overclocking your cpu causes your activation > to fail. > > Al |
| | #8 (permalink) |
| | Re: Does Overclocking YOur CPU cause problems with your activation? how much more you overclock it makes a difference too may be for example me if instead of going from 400 to 550 i had gone 400 to 600 i might have gotten problem, the other thing if i remember well is the speed of the cpu(the frequency) has to be compatible with the ram too. if you talk too fast to the ram, the ram might not work properly, it's a mix of things that could've done what it did glad it working "Alfred Kaufmann" <al_kaufmann@xxxxxx> wrote in message news:29sgd3dgc9hfp3sleibl3bon5mo1mcekvm@xxxxxx Quote: >I have overclocked it again and noticed no problems. :-) > Al > > On Fri, 31 Aug 2007 10:04:43 -0400, "-Draino-" <guest@xxxxxx> > wrote: > Quote: >>Overclocking has NO effect on activation. >> >>Try again and see what happens. My system is overclocked and I did it >>AFTER >>I installed Vista U, NO PROBLEMS. >> >> >>D >> >> >>"Alfred Kaufmann" <al_kaufmann@xxxxxx> wrote in message >>news:8v6gd3laffjiu65alqofefc7josr53mpi8@xxxxxx Quote: >>>I overclocked my cpu this morning and it worked great but then I >>> noticed in the taskbar something about volume activation failed or >>> something like that - I did not see it until the system was shutting >>> down. I re-booted, turned off the overclocking and after Windows >>> booted I checked the computer properties - everything seems okay and >>> my operating system is still activated. >>> >>> It is truly a sad day if overclocking your cpu causes your activation >>> to fail. >>> >>> Al >>> |
| activation key problems!! help please!! | Vista account administration | |||
| activation problems.... | Vista account administration | |||
| Overclocking problems, Oc fine in XP, but the smallest overclock in vista = freeze | Overclocking & Cooling | |||
| Activation problems | Vista installation & setup | |||
| Help - Activation problems | Vista installation & setup | |||
