| | Why is my hard drive actubg as thour it is write-protected? I have been attempting to install a small but old calendar program to my hard drive and I receive the following message: "You are attempting to install to a write-protected drive, such as a CD-ROM, or a drive with no space. Please try again." I have lots of space on my hard disk -- but why does it indicate it is write-protected? Any suggestions would be appreciated. |
| | Re: Why is my hard drive actubg as thour it is write-protected? The key to your question is "old" Try right clicking it and properties / compatibility and choosing one of the choices that you know works.. "Bill" <williamvmcbride@xxxxxx> wrote in message news:uEt7xIO7HHA.5796@xxxxxx Quote: >I have been attempting to install a small but old calendar program to my >hard drive and I receive the following message: > > "You are attempting to install to a write-protected drive, such as a > CD-ROM, or a drive with no space. Please try again." > > I have lots of space on my hard disk -- but why does it indicate it is > write-protected? Any suggestions would be appreciated. |
| | Re: Why is my hard drive actubg as thour it is write-protected? I think grege means that you should use the compatibility wizard to install the program. If you had been able to install it but it wouldn't run, you would do as he suggested. The compatibility wizard is easiest to find by typing compatibility into the search box on control panel. "Bill" <williamvmcbride@xxxxxx> wrote in message news:uEt7xIO7HHA.5796@xxxxxx Quote: >I have been attempting to install a small but old calendar program to my >hard drive and I receive the following message: > > "You are attempting to install to a write-protected drive, such as a > CD-ROM, or a drive with no space. Please try again." > > I have lots of space on my hard disk -- but why does it indicate it is > write-protected? Any suggestions would be appreciated. |
| | Re: Why is my hard drive actubg as thour it is write-protected? I think little johnny barnes means "the search box on the start menu", not control panel "John Barnes" <jbarnes@xxxxxx> wrote in message news:uPPf8aO7HHA.1444@xxxxxx Quote: >I think grege means that you should use the compatibility wizard to install >the program. If you had been able to install it but it wouldn't run, you >would do as he suggested. The compatibility wizard is easiest to find by >typing compatibility into the search box on control panel. > > "Bill" <williamvmcbride@xxxxxx> wrote in message > news:uEt7xIO7HHA.5796@xxxxxx Quote: >>I have been attempting to install a small but old calendar program to my >>hard drive and I receive the following message: >> >> "You are attempting to install to a write-protected drive, such as a >> CD-ROM, or a drive with no space. Please try again." >> >> I have lots of space on my hard disk -- but why does it indicate it is >> write-protected? Any suggestions would be appreciated. |
| | Re: Why is my hard drive actubg as thour it is write-protected? I think what John and Grege mean is that the install program is incorrectly interpreting your hard drive as being write-protected because it is attempting to write to some folder that Vista is not allowing it to write to and the installation program is misinterpreting the responses from Vista. Your HD is not write protected. Your old program is just wrong, that's all. The solution, though - if there is a solution, is the same: The compatibility wizard. Dale "Bill" <williamvmcbride@xxxxxx> wrote in message news:uEt7xIO7HHA.5796@xxxxxx Quote: >I have been attempting to install a small but old calendar program to my >hard drive and I receive the following message: > > "You are attempting to install to a write-protected drive, such as a > CD-ROM, or a drive with no space. Please try again." > > I have lots of space on my hard disk -- but why does it indicate it is > write-protected? Any suggestions would be appreciated. |
| | #6 (permalink) |
| | Re: Why is my hard drive actubg as thour it is write-protected? Many thanks to all for your good advice. The compatibility wizard worked like a charm. "Bill" <williamvmcbride@xxxxxx> wrote in message news:uEt7xIO7HHA.5796@xxxxxx Quote: >I have been attempting to install a small but old calendar program to my >hard drive and I receive the following message: > > "You are attempting to install to a write-protected drive, such as a > CD-ROM, or a drive with no space. Please try again." > > I have lots of space on my hard disk -- but why does it indicate it is > write-protected? Any suggestions would be appreciated. |
| | #7 (permalink) |
| | Re: Why is my hard drive actubg as thour it is write-protected? I read some of the other replies, and I don't know if they have helped any. - Is the program trying to write to a location that it does NOT have access to? - Try running it as Admin. - Try to make sure it has access to the location it is trying to write to. Many programmers assume everything they write has unlimited access to everything on the system. They don't seem to understand write permissions, and so may not have even coded the proper error message for whent they occur. -- http://xenomorph.net/ "Bill" <williamvmcbride@xxxxxx> wrote in message news:uEt7xIO7HHA.5796@xxxxxx Quote: >I have been attempting to install a small but old calendar program to my >hard drive and I receive the following message: > > "You are attempting to install to a write-protected drive, such as a > CD-ROM, or a drive with no space. Please try again." > > I have lots of space on my hard disk -- but why does it indicate it is > write-protected? Any suggestions would be appreciated. |
| Hard Drive is Write Protected? | Vista General | |||
| Disk Drive is write protected or Read only | Vista General | |||
| Write-Protected Flash Drive? | Vista General | |||
| Hard drive write protected | Vista General | |||
| USB Flash drive write protected | Vista hardware & devices | |||
