| Guest | Monitor resolution I am using a new Vista machine with my old 20" monitor. I like the resolution to be set at 1152x864 because of my old eyes. When I start the machine, there is a vertical strip on the right side with no image. I then change the resolution to another setting which restores the picture. I can then return to 1152x864. Is there a setting I can make to get the image to come up properly on the 1152x864 resolution? I had no trouble with the monitor when I was using win 98 (and using a setting of 800x600 which is close to the 1152x864 in Vista for some reason). Thanks Drew |
| Guest | Re: Monitor resolution "Drew" <drew@xxxxxx> wrote in message news:uadXNlk7HHA.1484@xxxxxx Quote: >I am using a new Vista machine with my old 20" monitor. I like the >resolution to be set at 1152x864 because of my old eyes. When I start the >machine, there is a vertical strip on the right side with no image. I then >change the resolution to another setting which restores the picture. I can >then return to 1152x864. > > Is there a setting I can make to get the image to come up properly on the > 1152x864 resolution? I had no trouble with the monitor when I was using > win 98 (and using a setting of 800x600 which is close to the 1152x864 in > Vista for some reason). Are you sure that this vertical strip on the right has nothing to do with Sidebar malfunctioning? Does the Sidebar appear there, or has it been disabled? ss |
| Guest | Re: Monitor resolution The sidebar is there and seems to be working properly. Drew "Synapse Syndrome" <synapse@xxxxxx> wrote in message news:urB9opk7HHA.2476@xxxxxx Quote: > "Drew" <drew@xxxxxx> wrote in message > news:uadXNlk7HHA.1484@xxxxxx Quote: >>I am using a new Vista machine with my old 20" monitor. I like the >>resolution to be set at 1152x864 because of my old eyes. When I start the >>machine, there is a vertical strip on the right side with no image. I >>then change the resolution to another setting which restores the picture. >>I can then return to 1152x864. >> >> Is there a setting I can make to get the image to come up properly on the >> 1152x864 resolution? I had no trouble with the monitor when I was using >> win 98 (and using a setting of 800x600 which is close to the 1152x864 in >> Vista for some reason). > > Are you sure that this vertical strip on the right has nothing to do with > Sidebar malfunctioning? Does the Sidebar appear there, or has it been > disabled? > > ss > |
| Guest | Re: Monitor resolution What is the maximum refresh rate the monitor will handle? Make sure you don't have the video card to exceed that. There is a big difference in 800x600 than 1152X848 lol. "Drew" <drew@xxxxxx> wrote in message news:uadXNlk7HHA.1484@xxxxxx Quote: >I am using a new Vista machine with my old 20" monitor. I like the >resolution to be set at 1152x864 because of my old eyes. When I start the >machine, there is a vertical strip on the right side with no image. I then >change the resolution to another setting which restores the picture. I can >then return to 1152x864. > > Is there a setting I can make to get the image to come up properly on the > 1152x864 resolution? I had no trouble with the monitor when I was using > win 98 (and using a setting of 800x600 which is close to the 1152x864 in > Vista for some reason). > > Thanks > > Drew > |
| Monitor Resolution | Graphic cards | |||
| Monitor Resolution Problem | Vista General | |||
| Monitor resolution | Vista General | |||
| Monitor resolution | Vista hardware & devices | |||
