| | Uninstalling Adobe Product Crazy issue!. I know this is not an Adobe group but this does involve the OS and could use all the help I can get. Short version of my issue is .. When I uninstall Adobe Premiere Elements 3.0 and perform a restart, my dvd drives are no longer available. Device manager notes them as failed, and I also noticed that Im unable to mount ISOs with Daemon Tools. I role back to a restore point and all is good. History to this problem.. I was having issues with my Adobe products so I was removing them all off my system... lots of CS3 products were recently removed but they did not cause an issue. As we speak Premiere Elements is the only app left, can remove it because it for some reason takes out my drives. Note: After the uninstall the drives are working. I then perform a restart, and then they are not. |
| | Re: Uninstalling Adobe Product Crazy issue!. Try this: http://support.microsoft.com/default...b/929461/en-us -- I Bleed Blue and Gold GO BEARS! "fern" <nomail@xxxxxx> wrote in message news:OQ63p397HHA.3624@xxxxxx Quote: >I know this is not an Adobe group but this does involve the OS and could use >all the help I can get. > Short version of my issue is .. > When I uninstall Adobe Premiere Elements 3.0 and perform a restart, my dvd > drives are no longer available. Device manager notes them as failed, and I > also noticed that Im unable to mount ISOs with Daemon Tools. > > I role back to a restore point and all is good. > > History to this problem.. > I was having issues with my Adobe products so I was removing them all off my > system... lots of CS3 products were recently removed but they did not cause > an issue. As we speak Premiere Elements is the only app left, can remove it > because it for some reason takes out my drives. > > Note: After the uninstall the drives are working. I then perform a restart, > and then they are not. > > |
| | Re: Uninstalling Adobe Product Crazy issue!. "Cal Bear '66" <xxx@xxxxxx> wrote in message news:293C454D-828E-416C-86A9-2DD33F0212C0@xxxxxx Quote: http://support.microsoft.com/kb/314060/ Which I found in the article you mentioned .. thanks, Ill give it a shot tonight. Quote: > -- > I Bleed Blue and Gold > GO BEARS! > > > "fern" <nomail@xxxxxx> wrote in message > news:OQ63p397HHA.3624@xxxxxx Quote: >>I know this is not an Adobe group but this does involve the OS and could >>use all the help I can get. >> Short version of my issue is .. >> When I uninstall Adobe Premiere Elements 3.0 and perform a restart, my >> dvd drives are no longer available. Device manager notes them as failed, >> and I also noticed that Im unable to mount ISOs with Daemon Tools. >> >> I role back to a restore point and all is good. >> >> History to this problem.. >> I was having issues with my Adobe products so I was removing them all off >> my system... lots of CS3 products were recently removed but they did not >> cause an issue. As we speak Premiere Elements is the only app left, can >> remove it because it for some reason takes out my drives. >> >> Note: After the uninstall the drives are working. I then perform a >> restart, and then they are not. >> >> > |
| Going Crazy, hotkeys or keyboad issue? | General Discussion | |||
| Problems Uninstalling Adobe CS3 Master Collection. | Software | |||
| Adobe 8.1 DEP Issue | Vista General | |||
| defragmenter uninstalling Adobe Flash player | Vista General | |||
