| | HELP: MSDN subscriber faces screwed up RFM on Vista RC1 install, how to fix? I have a messed-up situation involving an RC1 installation of Vista on a dev machine. I know there is an easy way out if someone can give me the right answer. The laptop has Vista RC1 installed on it. I want to install Vista Ultimate atop this installation, but life is very hard for now. Why? In a nutshell, I can't initate the upgrade process from the Windows Shell: I'm barred from access due to the expiration of RC1. It is refusing to activate. Worse, attempts to enter "reduced functionality mode" do not raise any kind of browser or other prompt. From reading around on the net, there are a bunch of ways that you can "break into" RFM, but these hacks depend on access to the web browser that RFM raises. I attempted to throw in the towel by initiating a clean install, but there is not enough disk space to do this (!). My options are to wipe the whole disk or clean off pieces of the old install. There's nothing sleazy going on here: I'm an MSDN subscriber, the equivalent of what used to be called MSDN Universal. The expiration of RC1 has NOT been extended using command-line statements. I am entitled to have a working install on the laptop. The issue is that I can't even start the upgrade process from the shell. If there is a magic activation number I can use to get at my shell for ten minutes or so, that would be sufficient. If there are command-line statements I could execute to give me shell access or otherwise start the upgrade, that would work too. I called MSDN support and the help was atypically worthless: they pointed me to a webpage that showed upgrade vs. clean install options for Vista versions over the RCs. Not helpful. Any help out there? |
| | Re: MSDN subscriber faces screwed up RFM on Vista RC1 install, how to fix? Sorry, there is no workaround for your dilemma. The expiration date of May 31, 2007 was hard-coded in the beta versions. See the following for more info: Windows Vista Beta 2, RC1 and RC2 set to expire: http://windowsvistablog.com/blogs/wi...to-expire.aspx ---------------------------------------------------------------------------------- "Ken Fine" wrote: I have a messed-up situation involving an RC1 installation of Vista on a dev machine. I know there is an easy way out if someone can give me the right answer. The laptop has Vista RC1 installed on it. I want to install Vista Ultimate atop this installation, but life is very hard for now. Why? In a nutshell, I can't initate the upgrade process from the Windows Shell: I'm barred from access due to the expiration of RC1. It is refusing to activate. Worse, attempts to enter "reduced functionality mode" do not raise any kind of browser or other prompt. From reading around on the net, there are a bunch of ways that you can "break into" RFM, but these hacks depend on access to the web browser that RFM raises. I attempted to throw in the towel by initiating a clean install, but there is not enough disk space to do this (!). My options are to wipe the whole disk or clean off pieces of the old install. There's nothing sleazy going on here: I'm an MSDN subscriber, the equivalent of what used to be called MSDN Universal. The expiration of RC1 has NOT been extended using command-line statements. I am entitled to have a working install on the laptop. The issue is that I can't even start the upgrade process from the shell. If there is a magic activation number I can use to get at my shell for ten minutes or so, that would be sufficient. If there are command-line statements I could execute to give me shell access or otherwise start the upgrade, that would work too. I called MSDN support and the help was atypically worthless: they pointed me to a webpage that showed upgrade vs. clean install options for Vista versions over the RCs. Not helpful. Any help out there? |
| | Re: MSDN subscriber faces screwed up RFM on Vista RC1 install, how to fix? Thanks for the reply, Carey, but I think you might be mistaken. Why? Because on my other development laptop computer, I was able to upgrade to Vista Ultimate sometime in late July/early August. It too had entered the mode where it randomly reboots after two hours. This is frustrating: I was alerted to the RFM well in advance of the death date, but I wasn't told that there would be no way to upgrade to a licensed copy, nor that different systems would display different behaviors in this regard. Somewhere somehow there is a hack around this, and I will keep looking if I can't get a MSFT-sanctioned solution. IMHO there needs to be a workaround for legit developers with legit MSDN subscriptions. Developers have an interest in testing new products like RCs in near-production, and it is not good to lock them out of their work. "Carey Frisch MVP]" <cnfrisch@xxxxxx> wrote in message news:EA64E139-63CD-47DB-B7D2-781E92136EB1@xxxxxx Quote: > Sorry, there is no workaround for your dilemma. > The expiration date of May 31, 2007 was hard-coded > in the beta versions. See the following for more info: > > Windows Vista Beta 2, RC1 and RC2 set to expire: > http://windowsvistablog.com/blogs/wi...to-expire.aspx > > ---------------------------------------------------------------------------------- > > "Ken Fine" wrote: > > I have a messed-up situation involving an RC1 installation of Vista on a > dev machine. I know there is an easy way out if someone can give me the > right answer. > > The laptop has Vista RC1 installed on it. I want to install Vista Ultimate > atop this installation, but life is very hard for now. Why? > > In a nutshell, I can't initate the upgrade process from the Windows Shell: > I'm barred from access due to the expiration of RC1. It is refusing to > activate. Worse, attempts to enter "reduced functionality mode" do not > raise > any kind of browser or other prompt. From reading around on the net, there > are a bunch of ways that you can "break into" RFM, but these hacks depend > on > access to the web browser that RFM raises. > > I attempted to throw in the towel by initiating a clean install, but there > is not enough disk space to do this (!). My options are to wipe the whole > disk or clean off pieces of the old install. > > There's nothing sleazy going on here: I'm an MSDN subscriber, the > equivalent > of what used to be called MSDN Universal. The expiration of RC1 has NOT > been > extended using command-line statements. I am entitled to have a working > install on the laptop. The issue is that I can't even start the upgrade > process from the shell. > > If there is a magic activation number I can use to get at my shell for ten > minutes or so, that would be sufficient. If there are command-line > statements I could execute to give me shell access or otherwise start the > upgrade, that would work too. > > I called MSDN support and the help was atypically worthless: they pointed > me > to a webpage that showed upgrade vs. clean install options for Vista > versions over the RCs. Not helpful. > > Any help out there? > |
| | Re: MSDN subscriber faces screwed up RFM on Vista RC1 install, how to fix? Hello Ken, I'm afraid that you have gone past the 'date of no return' regarding upgrading from a pre-release version of Vista. From the link Carey posted, the final hard-coded cut-off date was 28 August: After 31 May 2007, customers who continue to use pre-release versions of Windows Vista will be able to log in for 2-hour sessions to retrieve data. After 2 hours of use, the PC will automatically reboot without providing the opportunity to save data. The opportunity to log in normally for these 2-hour sessions will only be available until 28 August 2007. -- Jane, not plain 64 bit enabled :-)Batteries not included. Braincell on vacation ;-) MVP - Windows Shell/User "Ken Fine" <kenfine@xxxxxx> wrote in message news:0688BE14-BE54-4F6D-8C5A-16264F688957@xxxxxx Quote: > Thanks for the reply, Carey, but I think you might be mistaken. Why? > Because on my other development laptop computer, I was able to upgrade to > Vista Ultimate sometime in late July/early August. It too had entered the > mode where it randomly reboots after two hours. > > This is frustrating: I was alerted to the RFM well in advance of the death > date, but I wasn't told that there would be no way to upgrade to a > licensed copy, nor that different systems would display different > behaviors in this regard. > > Somewhere somehow there is a hack around this, and I will keep looking if > I can't get a MSFT-sanctioned solution. IMHO there needs to be a > workaround for legit developers with legit MSDN subscriptions. Developers > have an interest in testing new products like RCs in near-production, and > it is not good to lock them out of their work. > > > |
| | Not happy Re: MSDN subscriber faces screwed up RFM on Vista RC1 install, how to fix? Hi Jane, and thanks. This explains the behavior and my experience. I think Microsoft is not thinking on this one and I am not happy with its choices here: I say that being generally very supportive of MSFT developer tools on- and off-line. The target for RCs is developers. I don't understand why they would antagonize their developer base with this kind of irreversible cutoff. On one hand, you can argue that I had plenty of warning (though the last and most draconian of the deadlines was never communicated to me; I was working on a second larger laptop since I didn't travel for some months.) On the other, you can argue that developers are generally exempt from the usual restrictions and the licensing on products like MSDN support that contention. Here's a case where I have a valid paid upgrade in hand and I can't use it. I'm looking at a total rebuild of my primary development laptop and re-installation of all of my apps, settings, and webs because of an arbitrary hardcoded deadline and the want of a few days . It's a complete waste of my time and energy. Patch, please, young men of Redmond. One idea: validate against MSDN subscriber ID. You'll make everyone else mad but at least you won't destroy developers' ability to wrok. -KF "Jane C" <janecolman@xxxxxx> wrote in message news:7CBA06E5-3397-4CD2-B151-A0014FF8D854@xxxxxx Quote: > Hello Ken, > > I'm afraid that you have gone past the 'date of no return' regarding > upgrading from a pre-release version of Vista. From the link Carey > posted, the final hard-coded cut-off date was 28 August: > > After 31 May 2007, customers who continue to use pre-release versions of > Windows Vista will be able to log in for 2-hour sessions to retrieve data. > After 2 hours of use, the PC will automatically reboot without providing > the opportunity to save data. The opportunity to log in normally for > these 2-hour sessions will only be available until 28 August 2007. > > > -- > Jane, not plain 64 bit enabled :-)> Batteries not included. Braincell on vacation ;-) > MVP - Windows Shell/User > > "Ken Fine" <kenfine@xxxxxx> wrote in message > news:0688BE14-BE54-4F6D-8C5A-16264F688957@xxxxxx Quote: >> Thanks for the reply, Carey, but I think you might be mistaken. Why? >> Because on my other development laptop computer, I was able to upgrade to >> Vista Ultimate sometime in late July/early August. It too had entered the >> mode where it randomly reboots after two hours. >> >> This is frustrating: I was alerted to the RFM well in advance of the >> death date, but I wasn't told that there would be no way to upgrade to a >> licensed copy, nor that different systems would display different >> behaviors in this regard. >> >> Somewhere somehow there is a hack around this, and I will keep looking if >> I can't get a MSFT-sanctioned solution. IMHO there needs to be a >> workaround for legit developers with legit MSDN subscriptions. Developers >> have an interest in testing new products like RCs in near-production, and >> it is not good to lock them out of their work. >> >> >> |
| | #6 (permalink) |
| | "Resolution" Re: Not happy Re: MSDN subscriber faces screwed up RFM on Vista RC1 install, how to fix? My ultimate resolution to this issue is being effected now. After some poking, I figured out I could boot to safe mode. I useed RegEdit to display the RC I was running. I was running RC2. Microsoft says that only a clean install is possible going RC2->RTM. Some online report making it work -- sort of -- but I'm not going to chance it. Am nuking my old installation as we speak. Going into Safe Mode at least allowed me to clear off enough disk space to do the clean install. In the future it would be cool if Microsoft could give devs a means of bypassing the lockout experience, which wasted a lot of my time. -KF Quote: > I think Microsoft is not thinking on this one and I am not happy with its > choices here: I say that being generally very supportive of MSFT developer > tools on- and off-line. The target for RCs is developers. I don't > understand why they would antagonize their developer base with this kind > of irreversible cutoff. On one hand, you can argue that I had plenty of > warning (though the last and most draconian of the deadlines was never > communicated to me; I was working on a second larger laptop since I didn't > travel for some months.) On the other, you can argue that developers are > generally exempt from the usual restrictions and the licensing on products > like MSDN support that contention. > > Here's a case where I have a valid paid upgrade in hand and I can't use > it. I'm looking at a total rebuild of my primary development laptop and > re-installation of all of my apps, settings, and webs because of an > arbitrary hardcoded deadline and the want of a few days . It's a complete > waste of my time and energy. > > Patch, please, young men of Redmond. One idea: validate against MSDN > subscriber ID. You'll make everyone else mad but at least you won't > destroy developers' ability to wrok. > > -KF > > > "Jane C" <janecolman@xxxxxx> wrote in message > news:7CBA06E5-3397-4CD2-B151-A0014FF8D854@xxxxxx Quote: >> Hello Ken, >> >> I'm afraid that you have gone past the 'date of no return' regarding >> upgrading from a pre-release version of Vista. From the link Carey >> posted, the final hard-coded cut-off date was 28 August: >> >> After 31 May 2007, customers who continue to use pre-release versions of >> Windows Vista will be able to log in for 2-hour sessions to retrieve >> data. After 2 hours of use, the PC will automatically reboot without >> providing the opportunity to save data. The opportunity to log in >> normally for these 2-hour sessions will only be available until 28 August >> 2007. >> >> >> -- >> Jane, not plain 64 bit enabled :-)>> Batteries not included. Braincell on vacation ;-) >> MVP - Windows Shell/User >> >> "Ken Fine" <kenfine@xxxxxx> wrote in message >> news:0688BE14-BE54-4F6D-8C5A-16264F688957@xxxxxx Quote: >>> Thanks for the reply, Carey, but I think you might be mistaken. Why? >>> Because on my other development laptop computer, I was able to upgrade >>> to Vista Ultimate sometime in late July/early August. It too had entered >>> the mode where it randomly reboots after two hours. >>> >>> This is frustrating: I was alerted to the RFM well in advance of the >>> death date, but I wasn't told that there would be no way to upgrade to a >>> licensed copy, nor that different systems would display different >>> behaviors in this regard. >>> >>> Somewhere somehow there is a hack around this, and I will keep looking >>> if I can't get a MSFT-sanctioned solution. IMHO there needs to be a >>> workaround for legit developers with legit MSDN subscriptions. >>> Developers have an interest in testing new products like RCs in >>> near-production, and it is not good to lock them out of their work. >>> >>> >>> |
| | #7 (permalink) |
| | Re: "Resolution" Re: Not happy Re: MSDN subscriber faces screwed up RFM on Vista RC1 install, how to fix? I can't understand why anyone would want to develop for or test on RC1 or RC2. They are different from RTM and the work would potentially be worthless. The warning about cutoff dates was clear in the documentation if you read it, which you should have because you agreed to it when you downloaded and installed. -- Frank Saunders, MS-MVP OE/WM Do not send mail. "Ken Fine" <kenfine@xxxxxx> wrote in message news:48EC756A-B3D2-4151-850A-3936371708E9@xxxxxx Quote: > My ultimate resolution to this issue is being effected now. After some > poking, I figured out I could boot to safe mode. I useed RegEdit to > display the RC I was running. I was running RC2. Microsoft says that only > a clean install is possible going RC2->RTM. Some online report making it > work -- sort of -- but I'm not going to chance it. Am nuking my old > installation as we speak. > > Going into Safe Mode at least allowed me to clear off enough disk space to > do the clean install. > > In the future it would be cool if Microsoft could give devs a means of > bypassing the lockout experience, which wasted a lot of my time. > Quote: >> I think Microsoft is not thinking on this one and I am not happy with its >> choices here: I say that being generally very supportive of MSFT >> developer tools on- and off-line. The target for RCs is developers. I >> don't understand why they would antagonize their developer base with this >> kind of irreversible cutoff. On one hand, you can argue that I had plenty >> of warning (though the last and most draconian of the deadlines was never >> communicated to me; I was working on a second larger laptop since I >> didn't travel for some months.) On the other, you can argue that >> developers are generally exempt from the usual restrictions and the >> licensing on products like MSDN support that contention. >> >> Here's a case where I have a valid paid upgrade in hand and I can't use >> it. I'm looking at a total rebuild of my primary development laptop and >> re-installation of all of my apps, settings, and webs because of an >> arbitrary hardcoded deadline and the want of a few days . It's a complete >> waste of my time and energy. >> >> Patch, please, young men of Redmond. One idea: validate against MSDN >> subscriber ID. You'll make everyone else mad but at least you won't >> destroy developers' ability to wrok. >> >> "Jane C" <janecolman@xxxxxx> wrote in message >> news:7CBA06E5-3397-4CD2-B151-A0014FF8D854@xxxxxx Quote: >>> Hello Ken, >>> >>> I'm afraid that you have gone past the 'date of no return' regarding >>> upgrading from a pre-release version of Vista. From the link Carey >>> posted, the final hard-coded cut-off date was 28 August: >>> >>> After 31 May 2007, customers who continue to use pre-release versions of >>> Windows Vista will be able to log in for 2-hour sessions to retrieve >>> data. After 2 hours of use, the PC will automatically reboot without >>> providing the opportunity to save data. The opportunity to log in >>> normally for these 2-hour sessions will only be available until 28 >>> August 2007. >>> >>> "Ken Fine" <kenfine@xxxxxx> wrote in message >>> news:0688BE14-BE54-4F6D-8C5A-16264F688957@xxxxxx >>>> Thanks for the reply, Carey, but I think you might be mistaken. Why? >>>> Because on my other development laptop computer, I was able to upgrade >>>> to Vista Ultimate sometime in late July/early August. It too had >>>> entered the mode where it randomly reboots after two hours. >>>> >>>> This is frustrating: I was alerted to the RFM well in advance of the >>>> death date, but I wasn't told that there would be no way to upgrade to >>>> a licensed copy, nor that different systems would display different >>>> behaviors in this regard. >>>> >>>> Somewhere somehow there is a hack around this, and I will keep looking >>>> if I can't get a MSFT-sanctioned solution. IMHO there needs to be a >>>> workaround for legit developers with legit MSDN subscriptions. >>>> Developers have an interest in testing new products like RCs in >>>> near-production, and it is not good to lock them out of their work. |
| | #8 (permalink) |
| | Re: "Resolution" Re: Not happy Re: MSDN subscriber faces screwed up RFM on Vista RC1 install, how to fix? Actually the freebie run out and now the pants pocket is almost or completely sewn tight, -- Peter Please Reply to Newsgroup for the benefit of others Requests for assistance by email can not and will not be acknowledged. "Frank Saunders, MS-MVP OE/WM" <franksaunders@xxxxxx> wrote in message news:0403326E-ABFE-460B-BD0F-C5499A251AB0@xxxxxx Quote: >I can't understand why anyone would want to develop for or test on RC1 or > RC2. They are different from RTM and the work would potentially be > worthless. The warning about cutoff dates was clear in the documentation if > you read it, which you should have because you agreed to it when you > downloaded and installed. > > -- > Frank Saunders, MS-MVP OE/WM > Do not send mail. > > "Ken Fine" <kenfine@xxxxxx> wrote in message > news:48EC756A-B3D2-4151-850A-3936371708E9@xxxxxx Quote: >> My ultimate resolution to this issue is being effected now. After some >> poking, I figured out I could boot to safe mode. I useed RegEdit to >> display the RC I was running. I was running RC2. Microsoft says that only >> a clean install is possible going RC2->RTM. Some online report making it >> work -- sort of -- but I'm not going to chance it. Am nuking my old >> installation as we speak. >> >> Going into Safe Mode at least allowed me to clear off enough disk space to >> do the clean install. >> >> In the future it would be cool if Microsoft could give devs a means of >> bypassing the lockout experience, which wasted a lot of my time. >> Quote: >>> I think Microsoft is not thinking on this one and I am not happy with its >>> choices here: I say that being generally very supportive of MSFT >>> developer tools on- and off-line. The target for RCs is developers. I >>> don't understand why they would antagonize their developer base with this >>> kind of irreversible cutoff. On one hand, you can argue that I had plenty >>> of warning (though the last and most draconian of the deadlines was never >>> communicated to me; I was working on a second larger laptop since I >>> didn't travel for some months.) On the other, you can argue that >>> developers are generally exempt from the usual restrictions and the >>> licensing on products like MSDN support that contention. >>> >>> Here's a case where I have a valid paid upgrade in hand and I can't use >>> it. I'm looking at a total rebuild of my primary development laptop and >>> re-installation of all of my apps, settings, and webs because of an >>> arbitrary hardcoded deadline and the want of a few days . It's a complete >>> waste of my time and energy. >>> >>> Patch, please, young men of Redmond. One idea: validate against MSDN >>> subscriber ID. You'll make everyone else mad but at least you won't >>> destroy developers' ability to wrok. >>> >>> "Jane C" <janecolman@xxxxxx> wrote in message >>> news:7CBA06E5-3397-4CD2-B151-A0014FF8D854@xxxxxx >>>> Hello Ken, >>>> >>>> I'm afraid that you have gone past the 'date of no return' regarding >>>> upgrading from a pre-release version of Vista. From the link Carey >>>> posted, the final hard-coded cut-off date was 28 August: >>>> >>>> After 31 May 2007, customers who continue to use pre-release versions of >>>> Windows Vista will be able to log in for 2-hour sessions to retrieve >>>> data. After 2 hours of use, the PC will automatically reboot without >>>> providing the opportunity to save data. The opportunity to log in >>>> normally for these 2-hour sessions will only be available until 28 >>>> August 2007. >>>> >>>> "Ken Fine" <kenfine@xxxxxx> wrote in message >>>> news:0688BE14-BE54-4F6D-8C5A-16264F688957@xxxxxx >>>>> Thanks for the reply, Carey, but I think you might be mistaken. Why? >>>>> Because on my other development laptop computer, I was able to upgrade >>>>> to Vista Ultimate sometime in late July/early August. It too had >>>>> entered the mode where it randomly reboots after two hours. >>>>> >>>>> This is frustrating: I was alerted to the RFM well in advance of the >>>>> death date, but I wasn't told that there would be no way to upgrade to >>>>> a licensed copy, nor that different systems would display different >>>>> behaviors in this regard. >>>>> >>>>> Somewhere somehow there is a hack around this, and I will keep looking >>>>> if I can't get a MSFT-sanctioned solution. IMHO there needs to be a >>>>> workaround for legit developers with legit MSDN subscriptions. >>>>> Developers have an interest in testing new products like RCs in >>>>> near-production, and it is not good to lock them out of their work. |
| | #9 (permalink) |
| | Re: "Resolution" Re: Not happy Re: MSDN subscriber faces screwed up RFM on Vista RC1 install, how to fix? "Peter Foldes" <okf22@xxxxxx> wrote in message news:%23XpjSoa8HHA.5712@xxxxxx Actually the freebie run out and now the pants pocket is almost or completely sewn tight, <G> -- Frank Saunders, MS-MVP OE/WM Do not send mail. |
| I want to be an MSDN Subscriber - Just FYI | Vista General | |||
| How can I log a defect with MSDN subscriber ID? | Vista security | |||
| Successfully Downloaded Windows Vista X86 Beta 2 from MSDN Subscriber Downloads, just FYI. | Vista General | |||
| Microsoft Caves Under Heavy Pressure From One MSDN Subscriber | Vista General | |||
