| | Problem with Outlook after waking up from Sleep mode When my computer wakes up from Sleep mode, I can't send or receive messages in Outlook unless I reboot the computer. Closing and re-opening Outlook doesn't help. This was working fine until yesterday. I moved my .pst file to a Public folder so I could share it with another computer (it wouldn't let me share it from its original location -- that's a separate discussion topic...) I don't know why that would cause this problem, though. I installed the fix from this article, but it hasn't fixed the problem. http://support.microsoft.com/kb/933872/en-us I also found another post somewhere that suggested turning off the firewall, adding Outlook to the list of programs that can go through the firewall, then turning the firewall back on, but that didn't solve the problem either. Any ideas? I use Sleep mode a lot, but if it means I have to reboot each time to be able to send and receive e-mails, I might as well Shut Down instead of Sleep each time. Thank you. |
| Must Reset Network Adapter Upon Waking From Sleep Mode | Vista General | |||
| BSOD and unexpected shutdown shortly after waking from sleep mode | Vista performance & maintenance | |||
| Problem with Vista waking up from sleep | Vista General | |||
| Two Monitors - Only one is 'waking up' from sleep mode | Vista General | |||
| Internet Link drops when waking from Sleep mode | Vista General | |||
