| Guest | Vista Non-admin problem Hi all, The process doesn't have admin rights to open Registry Key, CreateFile, etc .... That is If i accesses any admin privileged resource that will be failed in vista(Even if the account type is administrator or standard user). Am using CreateFile. Its failed on TAP device, \\.\Global\{..}.tap: Access is denied. Do we need to set any specific Security policy for resolving this issue? Tried some of them under user control. But everything ends in failure. Can anyone help on this? Thanks. -- vista ------------------------------------------------------------------------ vista's Profile: http://forums.techarena.in/member.php?userid=30845 View this thread: http://forums.techarena.in/showthread.php?t=815553 http://forums.techarena.in |
| Guest | Re: Vista Non-admin problem Problem is we are getting the "Access is denied" error when we try to access the TAP device using CreateFile() function. Following are the various configuration changes we tried in Vista Business trial version to fix this CR. But everything ends in failure. 1. Tried the following Group Policy option in Vista Click Start, type gpedit.msc in the Search box, and press ENTER Go to the following branch: User Configuration | Administrative Templates | System Double-click Prevent access to registry editing tools Set it as Not Configured This option didnt helped. 2. Tried the following Security Policy options in Vista -> Enabled UAC to Run all administrators in admin approval mode and -> Network access for remotely accessing registry path and subpaths. Both options didnt helped. 3. Used third party utility(SubInACL) to add administrator permissions to every key in the registry from the link: http://www.microsoft.com/technet/tec...s/2006/11/UAC/ This is failed as we are not able to set the registry permissions using this utility procedures. 4. "Removable Storage Devices and Win Vista support" document provided by Microsoft Support. It was mentioned in that document that, "Application such as CD-burning applications or video games that use SCSI pass-through requests to send commands to devices require Full access to the storage device driver’s interface. However, such requests require elevated privileges to send commands to the drive, and in Windows Vista, the user is not granted elevated privileges by default, even if the user is a member of the Administrator group. Therefore, applications that assume that the access permissions for device access will be the same as the logged-on user’s permissions might break if an operation requires elevated privileges. Such an application would fail to open a handle to the storage device driver interface, and therefore the application would fail to work in Windows Vista. Important: It is not necessary to change these applications to be "UAC aware" and prompt the user for elevation of privileges for specific operations. Such a change would break application compatibility between Windows Vista and earlier versions of the Windows operating system. Instead, Windows Vista grants higher privileges by default to the Interactive User (IU) group for CD and DVD drives that have the Removable property set. This default allows applications to open a handle to removable media drives for sending SCSI pass-through requests without prompting the user for elevation of privileges." But we are not able to set REMOVABLE property for our TAP device, so that VISTA will grant access for that. 5. Changed the user permission in registry path as follow: i) Open regedit and go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class ii) Right click on the key to want to change and choose Permissions from the menu. iii) Click on the Advanced button and go to the Owner tab iv) Change the owner to the local machine's Administrators group, checking the Replace owner on subcontainers and objects box. v) Click on the OK buttons until the initial Permissions dialog has disappeared. We now have permission to view/edit the registry entries. If we are not a member of the Administrators group, then we need to add the user account to the list of accounts who can access that registry key. Once the above procedure was tried out, we are able to access the registry properly but still NetDirect failed due to CreateFile() function for TAP device. Can anyone please help on this? -- vista ------------------------------------------------------------------------ vista's Profile: http://forums.techarena.in/member.php?userid=30845 View this thread: http://forums.techarena.in/showthread.php?t=815553 http://forums.techarena.in |
| Guest | Re: Vista Non-admin problem Hi all, why Vista has two user types? When we select "Administrator" user type, there are some paths and registry not accessable by them. Since description of that user type said its "a user with admin rights". Then how can we enable full access to them? Is there anyway to do that? And also the created admin user don't know the actual admin credentials, username and passwd. Thanks in advance. -- vista ------------------------------------------------------------------------ vista's Profile: http://forums.techarena.in/member.php?userid=30845 View this thread: http://forums.techarena.in/showthread.php?t=815553 http://forums.techarena.in |
| Guest | Re: Vista Non-admin problem "vista" wrote: Quote: > > Hi all, > why Vista has two user types? When we select "Administrator" user > type, there are some paths and registry not accessable by them. Since > description of that user type said its "a user with admin rights". Then > how can we enable full access to them? Is there anyway to do that? And > also the created admin user don't know the actual admin credentials, > username and passwd. Thanks in advance. > > > -- > vista > ------------------------------------------------------------------------ > vista's Profile: http://forums.techarena.in/member.php?userid=30845 > View this thread: http://forums.techarena.in/showthread.php?t=815553 > > http://forums.techarena.in > > also in this newsgroup, to activate the main Administrator account and see if you can solve your problem using this account. Do not use this account any more than you need to - when you have finished using it, it is probably safer to disable it again. |
| Guest | Re: Vista Non-admin problem Hi, Thanks for your help. My application is automatically invoked by CreateProcess(). Is this right to place the below manifest file in the application executable folder. My exe : sample.exe Manifest file name : sample.exe.manifest Manifest file contents: <?xml version="1.0" encoding="utf-8" standalone="yes"?> <assembly xmlns="urn: schemas-microsoft-com:asm.v1" manifestVersion="1.0"> <assemblyIdentity version="1.0.0.0" processorArchitecture="X86" name="sample.exe" type="win32"/> <description> Sample Exe Description</description> <!-- Identify the application security requirements. --> <trustInfo xmlns="urn: schemas-microsoft-com:asm.v3"> <security> <requestedPrivileges> <requestedExecutionLevel level="asInvoker" uiAccess="false"/> </requestedPrivileges> </security> </trustInfo> </assembly> Will Vista pick it up automatically when i call my application .exe? Will this manifest file work for both user types, 'Standard user' and 'Administrator'? Do we need to do any specific changes in this file content? -- vista ------------------------------------------------------------------------ vista's Profile: http://forums.techarena.in/member.php?userid=30845 View this thread: http://forums.techarena.in/showthread.php?t=815553 http://forums.techarena.in |
| Vista Admin Corrupt problem | General Discussion | |||
| Problem in creating multiple admin accounts - Vista Ultimate 64 bi | Vista account administration | |||
| Admin problem with vista | General Discussion | |||
| Admin access to Vista Registry Remote & locally in Admin Approval | Vista security | |||
| Vista admin problem | Vista General | |||
