1.    10 Sep 2007 #1
    Alan T Guest
    Harddisk problem
    My harddisk had recently installed Vista but then got a problem could not
    boot up.
    So I need to reinstall Vista.
    However, in the beginning of the re-installation, Vista detected my harddisk
    had prvious Vista and said all files will be put into a separate folder,
    that's fine.
    Then it showed the partition table that I selected the primary partition
    (100 GB of 320 GB space) , when I click the partition, the message at the
    bottom of the screen showed the message:
    "This disk may fail soon. if other harddisk are available, install Windows
    to another location."
    Then I click next and go ahead.
    This time re-installation finished the steps: Copy files, Expand files,
    Install features, Install updates but said "Cannot goto next phase of
    installation".
    I need to reinstall, this time I deleted my 100Gb partition and format the
    whole space (320 GB) and went thro the all steps and finished.
    Vista installation seems detected my harddisk had a problem, but no idea
    what problem it is.
    Actually, in my previous Vista in this harddisk, it alwasys pop up a box say
    the harddisk had a problem, telling me to backup the data.
    My harddisk is Seagate 320GB, 16 MB cache one.
  2.    10 Sep 2007 #2
    Saucy Guest
    Re: Harddisk problem
    "Alan T" <alanNOSPAMpltse@xxxxxx> wrote in message
    news:ulxl0NA9HHA.2004@xxxxxx
    > boot up.
    > harddisk
    > that's fine.
    > installation".
    > what problem it is.
    > say
    Well you could run chkdsk (full) and do other harddrive diagnostics. Your
    harddrive may be failing, so if you have important files on there consider
    backing up to another location.
    If it is your harddrive then you will need another. Many harddrives have a
    year warranty or more, so you can return it and will receive an equivalent.
    Saucy
  3.    10 Sep 2007 #3
    Alan T Guest
    So in what situation I can return to the vendor (Seagate)?
    ie. how can I tell the evidence that the harddisk is dead?
    "Saucy" <saucy538347334873772.sjhdf@xxxxxx> wrote in message
    news:OADfFfA9HHA.1204@xxxxxx
    not
    > > boot up.
    > > harddisk
    > > that's fine.
    the
    Windows
    > > installation".
    the
    > > what problem it is.
    > > say
    equivalent.
    > Saucy
  4.    11 Sep 2007 #4
    Saucy Guest
    news:exzutbB9HHA.5316@xxxxxx
    > not
    >> > boot up.
    >> > harddisk
    >> > folder,
    >> > that's fine.
    >> > partition
    > the
    > Windows
    >> > installation".
    > the
    >> > idea
    >> > what problem it is.
    >> > box
    >> > say
    >> consider
    >> a
    > equivalent.
    >> Saucy
    It's been a while. I used to run a full scandisk from a DOS floppy (the
    Windows 98 boot disk) and one could get an actual visual count of sectors
    gone bad. You might try out some of the tools Seagate offers for
    diagnostics.
    Anwyay, contact who you bought it from and tell them you know it has gone
    south, and they should replace it for you on the spot - this is well the
    best option, so make sure to convince them. It would help to have the
    receipt. Otherwise you will have to go through Seagate. Do not remove any
    seals from the drive nor open it. Doing so voids all warranties.
    [Warranty and Returns Assistance - Seagate]
    http://www.seagate.com/www/en-us/sup...rns_assistance
    [SeaTools - Seagate (watch the URL wrap)]
    http://www.seagate.com/ww/v/index.js...00dd04090aRCRD
    Saucy
  5.    11 Sep 2007 #5
    ray Guest
    > boot up.
    > that's fine.
    > installation".
    > what problem it is.
    Modern hard drives have a built in 'health' checker referred to as 'SMART'
    - no, I don't recall the acronym. I'd suggest you check the drive SMART
    status.
  6.    11 Sep 2007 #6
    Alan T Guest
    Yes, my motherboard has this option in the BIOS, ie. S.M.A.R.T monitoring.
    I once enabled it and the POST always telling me a harddisk has a problem.
    However, it said channel 2 harddisk has a problem. The harddisk attach to
    channel is fine. This warning only happens when I use this 'faulty' harddisk
    to boot up. So I think the POST was referring to this harddisk but just
    wonder why it said channel 2, it should be channel 1.
    "ray" <ray@xxxxxx> wrote in message
    newsan.2007.09.11.15.45.01.41830@xxxxxx
    not
    > > boot up.
    harddisk
    > > that's fine.
    the
    Windows
    > > installation".
    the
    > > what problem it is.
    say
    > status.
Space in HardDisk
Hi!!! I need a script that monitors the hard drives of servers and when you reach a minimum space constraints, I send an email warning. How can...
VB Script
Problem with harddisk
Hi.... I have a strange problem with my harddisk. There'e a light idicator on my computer shows that if the harddisk is running or not. After...
General Discussion
Repartition of my harddisk
I just recived my new notebook with a single partition on it. I want to repartion my hardrive.......... i tried with disk managment tool but it is...
Vista performance & maintenance
upgrading harddisk
I had installed vista ultimate on a 120GB HD and I had another one with 400GB as a music storage now I brought a new 400gb disk and I want to...
Vista installation & setup
Harddisk - 8/16 MB cache
At the moment I got a 320 GB Seagate 16 MB cache storing data. Then I bought a 250 GB Maxtor 8 MB cache considering as primary partition of Vista....
Vista General
HardDisk & Flash Problem
Hi, I finally got Vista Ultimate installed with Visual Stuio, SQL Server, and the rest of the software that i use running perfectly. Things were...
Vista hardware & devices
USB 2.0 harddisk
> My external harddisk, USB 2.0, is slow! In Windows XP it works perfect but > in Vista 5600RC1 the data transfer is at the speed of a USB 1...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
