Vista - Problem with Hibernate
Old 07-01-2006   #1 (permalink)
Graham
G'day all.
I've encountered a problem and I'm not too sure which newsgroup is more
relevant, so I'll post it here.
Whenever I try to use Hibernate the computer restarts telling me that it did
not shutdown properly. This happens every time. I don't know if there is a
setting that I'm supposed to enable or not, and it's got me stumped.
It may tie in with another problem that I have found. In Device Driver, it
tells me that I have an unknown device. I can't figure out what the device
maybe, as I seem to be able to account for all of my hardware devices. So I
was thinking that maybe it's something to do with the motherboard drivers.
My system is:
AMD Athlon 3000+
Gigabyte 7VM400AM-RZ motherboard
1 Gig ram
2 x 120gb Seagate h/drives - using IDE mode at the moment not RAID
250mb Radeon 9550
DVD drive + DVD burner
I would be greatful for any help.
Graham
Old 07-01-2006   #2 (permalink)
Zapper
Re: Problem with Hibernate
I would disable the "unknown" item in device manager.
Have you installed any software lately? Did you have to force XP
compatibility for it? Does it seem like it would install device drivers?
I installed Pinnacle Studio 10 and it has hosed my machine, it takes
forever(5-10 mins) to try to go into hibernate and then can not not come out
of hibernate do to "issues" It seems to drop my USB bus during this
period...so I have a PS2 keyboard to allow me to get past the screen that
asks me if I want to try again, or drop all saved info..
"Graham" <elangy@iprimus.com.au> wrote in message
news:F294A723-D53E-4BDA-97AE-9FE3569CFB57@microsoft.com...
> G'day all.
> did not shutdown properly. This happens every time. I don't know if there
> is a setting that I'm supposed to enable or not, and it's got me stumped.
> I was thinking that maybe it's something to do with the motherboard
> drivers.
> My system is:
> AMD Athlon 3000+
> 1 Gig ram
> 250mb Radeon 9550
> Graham
Old 07-01-2006   #3 (permalink)
Colin Barnhorst
In other threads on here it has turned out be something like the game port
on an audio card, and such items. Don't worry too much about it since a lot
of beta drivers only provide basic functionality.
If you want to identify the device, right click on it and choose properties
and then the Details tab. Post back the device ID if a Google search
doesn't turn up anything. When searching, use the middle part of the ID.
> G'day all.
> drivers.
> My system is:
> AMD Athlon 3000+
> 1 Gig ram
> 250mb Radeon 9550
> Graham
Old 07-01-2006   #4 (permalink)
Graham
The unknown device was present after the initial installation, so I know
that it is not due to anything that I've installed. When I realised that I
couldn't identify what it was I did disable it.
I'm just hoping that I can get an answer about the Hibernate problem. I
prefer Hibernate to Sleep.
Thanks for the response.
Graham.
"Zapper" <Zapper@uribe-mahler.com> wrote in message
news:376AF935-21B7-4E24-B1C2-C3889421BB45@microsoft.com...
> out of hibernate do to "issues" It seems to drop my USB bus during this
>> G'day all.
>> it tells me that I have an unknown device. I can't figure out what the
>> device maybe, as I seem to be able to account for all of my hardware
>> devices. So I was thinking that maybe it's something to do with the
>> My system is:
>> AMD Athlon 3000+
>> 1 Gig ram
>> 250mb Radeon 9550
>> Graham
Old 07-01-2006   #5 (permalink)
Graham
Ok. The unknown device turns out to be the Joystick Port. Thanks for the
tip.
"Colin Barnhorst" <colinbarharst(remove)@msn.com> wrote in message
news:%23aUmTfNnGHA.4452@TK2MSFTNGP05.phx.gbl...
> lot of beta drivers only provide basic functionality.
> properties and then the Details tab. Post back the device ID if a Google
> search doesn't turn up anything. When searching, use the middle part of
> the ID.
>> G'day all.
>> My system is:
>> AMD Athlon 3000+
>> 1 Gig ram
>> 250mb Radeon 9550
>> Graham
Old 07-01-2006   #6 (permalink)
Colin Barnhorst
You're welcome.
news:5C5012AF-0AA4-4D2B-8944-ABDC85DAEE7A@microsoft.com...
> tip.
>> port on an audio card, and such items. Don't worry too much about it
>> since a lot of beta drivers only provide basic functionality.
>> the ID.
>>> G'day all.
>>> there is a setting that I'm supposed to enable or not, and it's got me
>>> stumped.
>>> My system is:
>>> AMD Athlon 3000+
>>> 1 Gig ram
>>> 250mb Radeon 9550
>>> Graham
Old 07-01-2006   #7 (permalink)
Graham
> G'day all.
As a follow up to my own post.
In the Performance Ratings and Tools screen it actually tells me that
certain drivers are causing my computer to go into Sleep and Hibernate
slowly. (This is not quite true as Sleep takes effect immediately, whereas
Hibernate crashes the computer.)
There are actually two drivers listed.
The first is ATIKMDAG.SYS which is the ATI Radeon kernel driver for the
graphics card.
The second is ACPI.SYS. This driver appears to have two problems associated
with it. The VIA Rhine Ethernet Adapter and the AMD K7 Processor.
So just a little digging around on my part would have given me the answers I
was looking for. Now to find the solutions - if they exist.
Thanks Zapper and Colin for taking the time to respond to my intial post.
Colins suggestion resolved a different issue.
hibernate problem Vista General
Hibernate Problem Vista General
Hibernate problem Vista General
Vista Hibernate Problem General Discussion
