Vista - System Restore Deleting Restore Points Automatically....
Old 09-13-2007   #11 (permalink)
Re: System Restore Deleting Restore Points Automatically....
Quote  Quote: Originally Posted by Bert Kinney View Post
Bowen wrote:
Hi Shawn,
Yes, Perfect Disk may be responsible for missing restore points particularly
if it is run before Vista loads.
Regards,
Bert Kinney MS-MVP Shell/User
All About System Restore in WinXP
Member: Welcome to DTS-L.org
Bert,
Thank you for the information. I will remember that one.
Old 09-13-2007   #12 (permalink)
Vista HP x64
Quote  Quote: Originally Posted by brink View Post
Bowen,
I would not think that they would do anything unless they had a feature that cleans junk off the hard drive.
For a test, you might bump up the size to 150 GB to see if it will hold more. If not, you can bump it back down.
Thanks, how do I raise the size? Like I said I'll try the Diskeeping thing. I'll try it tonight sometime and see what happens. BTW, it's got 7 restore points right now. I bet it's Perfect Disk. I'll test it tonight and see if it's the culprit or not.
Old 09-13-2007   #13 (permalink)
Quote  Quote: Originally Posted by Bowen View Post
Bowen,
The second step will show you how in this tutorial. I hope it works out with the test.
System Restore - disk space
Old 09-17-2007   #14 (permalink)
Vista HP x64
OK, well I finally got around to using Perfect Disk and I've confirmed that it's the culprit. Diskeeper was doing the same thing too. Prior to running Perfect Disk, I had 9 Restore Points saved. Then I ran PD and it wanted to do a boot time defrag and I agreed and after it finished, all my restore points were gone.
This is OK since my system is running flawlessly right now, but what I want to know is how can I program PD to stay away from the Restore Points?
Thanks for all your help. At least I know the cause, so the problem is 50% solved IMO. I know I could simply uninstall PD, but that's not a real fix since Diskeeper does this too. There's got to be a way to work around this.
Old 09-17-2007   #15 (permalink)
Bowen,
Well, that stinks. I do not use those programs, but surely there must be a setting, in the options somewhere in the program, to uncheck some cleaning feature causing this.
Old 09-17-2007   #16 (permalink)
Vista HP x64
Here's another thread at Techguy Forums and Rollin' Rog, one of the mods there contacted Raxco. They said that it shouldn't be doing it. It happened to him too, BTW. Anyway check out the thread here: System Restore Deleting Restore Points Automatically.... - Tech Support Guy Forums
Post #9 is the one where he contacted them and they responded.
Old 09-17-2007   #17 (permalink)
Bert Kinney
I had the same experience with PerfectDisk and Vista. Restore points should
not be deleted unless PerfectDisk is run at boot up. Running PerfectDisk
from within Vista should be save.
Regards,
http://bertk.mvps.org
Member: http://dts-l.org
> Points?
> around this.
Old 09-18-2007   #18 (permalink)
Vista HP x64
Regards,
Bowen wrote:
So as long as you don't run a boot time defrag, it shouldn't delete restore points then? I'll have to try that out because I really like Perfect Disk. I have Diskeeper too and I like it better (PerfectDisk) than Diskeeper because...well it's faster.
*EDIT*
Well, another poster said in the techguy forums said that he ran PD (in Vista) and it did delete his older restore points. What options did you select when you ran PD in Windows?
Old 09-19-2007   #19 (permalink)
Bert Kinney
Bowen wrote:
Quote:
> Bert Kinney;455024 Wrote:
Quote:
>> Hi,
>> should
>> PerfectDisk
>> Regards,
>> 'All About System Restore in WinXP' (http://bertk.mvps.org)
>> Member: 'Welcome to DTS-L.org' (http://dts-l.org)
That's correct. Give it try and let us know the results.
Regards,
Old 09-21-2007   #20 (permalink)
Vista HP x64
Regards,
Well, you were correct Bert, it didn't delete any restore points within Windows. However, it took an hour and sixteen minutes to complete and PD said I didn't even need to defrag. The thing about doing a boot time defrag is that it only takes......well it only took 5 minutes the last time I did it, but of course it wipes out the restore points.
I think what I'm gonna do is go ahead and do boot time defrags and then immediately make a manual restore point afterwards. I imagine the boot time defrag only defrags certain files, where the Windows defrag does the entire hard drive. At least now I know though.
Do you happen to know a workaround for doing a boot time defrag while saving your restore points? This would be a little annoying and out of the way, but couldn't you say, burn your restore points (at least some of them) to a DVD-RW and then do a boot time defrag and then just copy them back afterwards. Would that work per chance?
System Restore.... Restore Points Vista General
System Restore: do restore points persist after a restore? Vista General
system restore points not created automatically Vista General
System restore unable to restore points Vista General
system restore (automatic daily restore points) Vista General
