Vista - System Restore Deleting Restore Points Automatically....
Old 09-23-2007   #21 (permalink)
Bert Kinney
Re: System Restore Deleting Restore Points Automatically....
Quote:
> Bert Kinney Wrote:
Quote:
>> That's correct. Give it try and let us know the results.
>> Regards,
>> Bert Kinney MS-MVP Shell/User
>> 'All About System Restore in WinXP' (http://bertk.mvps.org)
>> Member: 'Welcome to DTS-L.org' (http://dts-l.org)
Bowen wrote:
Quote:
> Well, you were correct Bert, it didn't delete any restore points within
> Windows. However, it took an hour and sixteen minutes to complete and
> PD said I didn't even need to defrag. The thing about doing a boot time
> defrag is that it only takes......well it only took 5 minutes the last
> time I did it, but of course it wipes out the restore points.
> I think what I'm gonna do is go ahead and do boot time defrags and then
> immediately make a manual restore point afterwards.
And make sure the system is running correctly before hand. And remember all
Shadow Copy's will be effected including Previous Versions.
Quote:
> I imagine the boot
> time defrag only defrags certain files, where the Windows defrag does
> the entire hard drive. At least now I know though.
You may want to check with Raxco Support on this.
Quote:
> Do you happen to know a workaround for doing a boot time defrag while
> saving your restore points?
I don't know of any workaround to this.
Quote:
> This would be a little annoying and out of
> the way, but couldn't you say, burn your restore points (at least some
> of them) to a DVD-RW and then do a boot time defrag and then just copy
> them back afterwards. Would that work per chance?
No, this will not work.
Regards,
Member: http://dts-l.org
System Restore.... Restore Points Vista General
System Restore: do restore points persist after a restore? Vista General
system restore points not created automatically Vista General
System restore unable to restore points Vista General
system restore (automatic daily restore points) Vista General
