Vista - Slow WiFi connection during startup
Old 09-13-2007   #1 (permalink)
Sabian Smith
Vista startup is being delayed by about 50 seconds due to (I think) slow
startup of the Wiresless network connection (which otherwise works well).
The desktop/sidebar appears reasonably fast (about 45 seconds from BIOS),
but after the sidebar appears there is a 50 second delay with NO disk
activity. During this time, it appears the service WORKSTATION is trying to
load ("Starting.."). It finally starts after 50 seconds, and the rest of the
startup process finishes.
During this pause, the Network icon in System Tray (2 computers) has a red
X, then a yellow exclamation, and about a minute later the planet symbol
with a working internet connection. I suspect this slow wireless connection
is delaying the Workstation Service startup? Any ideas why the wifi takes so
long to connect during bootup? Any way to further debug to isolate problem?
System Setup:
-Vaio SZ6 Santa Rosa laptop with Intel 4965AGN (80211b/g/n)
-Vista Business 32 bit, local workgroup over LAN
-D-Link (DI624) router, dynamic DHCP, connected to cablemodem.
-No difference in delay using static IP assignment
-WPA/PSK security
-NIC not allowed to connect to "alternative SSID"
-Up to date Vista, Intel NIC drivers, router firmware.
Old 12-06-2007   #2 (permalink)
johnnyjt
RE: Slow WiFi connection during startup
Gee your lucky!
Right now I have to wait 10-15 minutes
before Vista reconizes my Network!
JohnnyJT
South Philly
> System Setup:
> -WPA/PSK security
Old 01-04-2008   #3 (permalink)
JPW
Re: Slow WiFi connection during startup
After having the same problem I did some research and figured it out.
It is your anti-virus. Windows Vista comes with one called Windows
Defender.
It is Windows Defender that is causing you this problem.
to solve this problem:
1. Open control panel
2. click on classic view on the left hand panel
3. Scroll down to Windows Defender
4. Double click it to launch it.
5. Click on "tools"
6. click on "Options"
7. Scroll to the bottom
8. Uncheck "Use Windows Defender"
9. Click "Save"
Restart your computer, You should notice an immediate difference.
If you are still having the problem, then also turn off your windows
firewall.
Old 01-04-2008   #4 (permalink)
johnnyjt
Hi JPW
All I did to get it to work right was to re-install the WiFi card drivers!
Some how Logitech SetPoint corrupted the driver, they won't acknowlage this!
Thanks anyway
JohnnyJt
> Defender.
> 5. Click on "tools"
> 9. Click "Save"
> firewall.
> JPW
> JPW's Profile: http://forums.techarena.in/member.php?userid=38870
> View this thread: http://forums.techarena.in/showthread.php?t=817449
WiFi Connection keeps dropping Network & Sharing
Business x64: Network Connection Slow to Startup with PC Network & Sharing
WiFi looses connection Drivers
Slow Wifi Transfer But / Faster Wifi Internet Vista networking & sharing
Automatic WiFi Connection Vista networking & sharing
