Vista - BSOD NVSTOR64.sys irql not less ot equal to zero
Old 09-14-2007   #1 (permalink)
Tokraspy
Please help me with this Vista X64 error message,
driver_irql_not_less_or_equal
nvstor64.sys - address fffff9800053cb0a base at fffff98000537000, datestamp
458d544e
collecting data for crash dump ...
initializing disk for crash dump ...
Old 09-14-2007   #2 (permalink)
Synapse Syndrome
Re: BSOD NVSTOR64.sys irql not less ot equal to zero
"Tokraspy" <Tokraspy@xxxxxx> wrote in message
news5A90702-197A-4F2F-8A4A-DA9FDDE564AA@xxxxxx
> datestamp
> 458d544e
Your nVidia drivers are causing the crash. Try upgrading to the latest ones
if possible.
ss.
Old 09-14-2007   #3 (permalink)
Tokraspy
tried that and the error becomes, bsod:-
a clock interrupt was not received on a secondary processor within the
allocated time interval
just not understanding whats goin on!
> > datestamp
> > 458d544e
> if possible.
> ss.
Old 09-14-2007   #4 (permalink)
Michael Solomon
news:C0B7EC18-2E3C-41DD-AA7A-A884F6954433@xxxxxx
>> > datestamp
>> > 458d544e
>> ones
>> if possible.
>> ss.
You have to start with what you do understand, the error message points to
an issue with your nVidia drivers, implication being, all else stems from
that. Fix your drivers and see if the error disappears.
Preliminarily, it seems the GPU did not properly send or sent corrupted
information to the CPU, or information that could not be read or simply was
not received by one of the cores on what appears to be a system with a dual
core processor. Nonetheless, the fault appears to be an issue with the
graphics card, you need to check for the latest Vista Compatible drivers for
your card.
Michael Solomon
Backup is a PC user's best friend
DTS-L.Org: http://www.dts-l.org/
Still Undiagnosed IRQL NOT LESS OR EQUAL bsod Vista General
BSOD - Driver IRQL not less or equal Vista performance & maintenance
BSOD IRQL not less than or equal Vista installation & setup
IRQL Not LESS Or Equal Vista General
BSOD in TCPIP.SYS with IRQL less/equal Vista networking & sharing
