Vista - problem with creating form with check boxes
Old 09-15-2007   #1 (permalink)
creating interactive forms in word
The check boxes and drop-down boxes are not working. I can put them into the
form but they will not activate so user can click on them. Any suggestions?
In the old version it was a matter of unlocking design mode but this is not
working.
Old 09-16-2007   #2 (permalink)
Val
Re: problem with creating form with check boxes
Suggest you post in a forum devoted to whatever program you're using to
create your form.
And when you do post, give the program name and version, and describe more
fully what you've done, and the results.
"creating interactive forms in word" <creating interactive forms in
word@xxxxxx> wrote in message
news:38D5EFAC-6E98-4E6D-AF3C-586C27754510@xxxxxx
the
working.
font size in form boxes/fields Vista performance & maintenance
Icon Check Boxes Vista General
Creating new Printer Form Vista print fax & scan
No check boxes in Windows Mail Vista mail
Check Boxes in Contact List Vista mail
