Vista - Re: IE7 kept crashing after installing and running Code Cleaner?
Old 09-16-2007   #1 (permalink)
PA Bear
Crossposted to IE General, Vista General, and Vista Performance/Maintenance.
See this recent forum conversation about using Registry cleaners:
http://aumha.net/viewtopic.php?t=28099
Should you choose to use CCleaner's "Issues" function again, make sure you
accept the prompt to back-up the changes you're about to make. If problems
arise afterward, use these back-ups to correct the problem instead of System
Restore/Go-Back.
~Robear Dyer (PA Bear)
MS MVP-Windows (IE, OE, Security, Shell/User) since 2002
AumHa VSOP & Admin http://aumha.net; DTS-L http://dts-l.org/
SnowFire wrote:
Quote:
> Sorry that should have been CCleaner (I assume it stood for Code Cleaner).
> It has no direct attachment to IE7.... just after installing and
> cleaning-up the hard drive I had problems with IE7 locking-up..... had to
> use Task Manager to close IE7 ?
> "PA Bear" <PABearMVP@xxxxxx> wrote in message
> news:eYGr2859HHA.4880@xxxxxx
Quote:
>> What "Code Cleaner"? Is it supported in IE7? ...in Vista?
>> Those with IE7-specific questions or comments are asked to post to and
>> seek support in this newsgroup: microsoft.public.internetexplorer.general
>> On the web:
>> http://www.microsoft.com/communities...plorer.general
>> In your newsreader:
>> news://msnews.microsoft.com/microsof...plorer.general
>> SnowFire wrote:
Quote:
>>> IE7/ (Vista), IE7 kept crashing after installing and running Code
>>> Cleaner.
>>> Has anyone else had this problem? Used System Recovery to "Go-Back" and
>>> all
>>> now appears to work. I have used this utility on my previous XP computer
>>> and
>>> it gave no problems. Is there a Vista incompatibility problem? Does it
>>> remove
>>> IE associated "bits and pieces" best left alone?
>>> Any help/comments appreciated
Old 09-17-2007   #2 (permalink)
SnowFire
Thanks for the advise and the link
Mike
news:%23h5jmKH%23HHA.5840@xxxxxx
> problems arise afterward, use these back-ups to correct the problem
> instead of System Restore/Go-Back.
> SnowFire wrote:
>> Cleaner).
>>> On the web:
>>> In your newsreader:
>>>> Cleaner.
>>>> all
>>>> computer
>>>> and
>>>> remove
Help!!!! Please.... computer crashing after installing Microsoft .NET Framework 3.5 S Vista performance & maintenance
Dell running on Vista crashing continually Vista General
Re: IE7 kept crashing after installing and running Code Cleaner? Vista performance & maintenance
Explorer.exe Not running correctly (Crashing) Vista General
Need help with crashing while installing Vista installation & setup
