Vista - SLI Problem
Old 09-18-2007   #1 (permalink)
Shawn Malligan
SLI Problem
Hello
Running a Core 2 Quad 6600, 2 Albatron 8800 320mb GTS cards, 4gb (3gb under
Vista Premium 32bit) on an ASUS P5N-E SLI motherboard (latest Bios). When I
try to play Railroads or any of the Civilization games in SLI mode I get two
stripes going down the left hand side of the screen with the words SLI
during gameplay or bootup. This does not happen on the desktop or in single
card mode. Have not tried any other games since I have noticed the problem
and have been using Nivida 32bit Vista drivers 162.22 through to 163.69. I
have downloaded the MS Patches which are supposed to improve performance but
when I try to install them WIndows says they are not for my system. Has
anyone else been having this problem or knows what I can do?
Thanks Shawn
Old 09-18-2007   #2 (permalink)
Dave
Re: SLI Problem
"Shawn Malligan" <shawnmalligan@xxxxxx> wrote in message
newsE5583E6-E07E-4869-A42C-39D4C963202C@xxxxxx
Quote:
> Hello
> under Vista Premium 32bit) on an ASUS P5N-E SLI motherboard (latest Bios).
> When I try to play Railroads or any of the Civilization games in SLI mode
> I get two stripes going down the left hand side of the screen with the
> words SLI during gameplay or bootup. This does not happen on the desktop
> or in single card mode. Have not tried any other games since I have
> noticed the problem and have been using Nivida 32bit Vista drivers 162.22
> through to 163.69. I have downloaded the MS Patches which are supposed to
> improve performance but when I try to install them WIndows says they are
> not for my system. Has anyone else been having this problem or knows what
> I can do?
> Thanks Shawn
Have you tried changing the game's profile in nvidia control panel for
different types of sli mode?
Old 09-18-2007   #3 (permalink)
XP Pro
Re: SLI Problem
Under "3D Settings" make sure "Show SLI Visual Indicators" is turned off.
Old 09-18-2007   #4 (permalink)
Shawn Malligan
Re: SLI Problem
Hello
I tried the settings for SLI Performance Mode and get a single line across
the screen instead with SLI still on left side of screen. Where is the SLI
Indicators menu? Still using the Vista Nvidia control panel.
Thanks again Shawn
Old 09-18-2007   #5 (permalink)
Synapse Syndrome
Re: SLI Problem
> I can do?
I know it's off the point, but playing Civilization in SLI mode is just a
waste of electricity.
ss.
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
