| Guest | Taskbar auto hide does not work correctly. For the first two weeks I had my new Dell Inspiron 1520 (Vista Home Premium) the auto hide Taskbar worked correctly. Now the Taskbar is always visible when auto hide is on; the Taskbar is then on top of all windows, but when maximized the bottom of windows disappear under the Tool Bar. When auto hide is turned off, all windows maximize to, but not under the Taskbar. Is there a solution to this problem? I found a work around (use Task Manager to kill explorer.exe, then run explorer.exe), but I'd rather find a permanent solution, or at least a report that Microsoft is working on the problem. Phil Weldon |
| Guest | Re: Taskbar auto hide does not work correctly. Good luck. I had similar problems, and used the same workaround, on both XP86 and XP64. XP64 eventually fixed itself, XP86 never did, but isn't used much. "Phil Weldon" <not.disclosed@xxxxxx> wrote in message news:13f13n5ig0qna27@xxxxxx Quote: > For the first two weeks I had my new Dell Inspiron 1520 (Vista Home > Premium) > the auto hide Taskbar worked correctly. Now the Taskbar is always visible > when auto hide is on; the Taskbar is then on top of all windows, but when > maximized the bottom of windows disappear under the Tool Bar. When auto > hide is turned off, all windows maximize to, but not under the Taskbar. > > Is there a solution to this problem? I found a work around (use Task > Manager to kill explorer.exe, then run explorer.exe), but I'd rather find > a > permanent solution, or at least a report that Microsoft is working on the > problem. > > Phil Weldon > > |
| Guest | Re: Taskbar auto hide does not work correctly. 'John Barnes' wrote: | Good luck. I had similar problems, and used the same workaround, on both | XP86 and XP64. XP64 eventually fixed itself, XP86 never did, but isn't used | much. _____ Thanks for the reply. You'd think that this time around that particular irritant would have be fixed. Perhaps there are some programs that, when run, set up the problem, which remains afterwards until restarting explore.exe or the system. Phil Weldon "John Barnes" <jbarnes@xxxxxx> wrote in message news:OeZkm$r%23HHA.4476@xxxxxx | | "Phil Weldon" <not.disclosed@xxxxxx> wrote in message | news:13f13n5ig0qna27@xxxxxx | > For the first two weeks I had my new Dell Inspiron 1520 (Vista Home | > Premium) | > the auto hide Taskbar worked correctly. Now the Taskbar is always visible | > when auto hide is on; the Taskbar is then on top of all windows, but when | > maximized the bottom of windows disappear under the Tool Bar. When auto | > hide is turned off, all windows maximize to, but not under the Taskbar. | > | > Is there a solution to this problem? I found a work around (use Task | > Manager to kill explorer.exe, then run explorer.exe), but I'd rather find | > a | > permanent solution, or at least a report that Microsoft is working on the | > problem. | > | > Phil Weldon | > | > | |
| Newbie | Re: Taskbar auto hide does not work correctly. Ok I came across this by accident, if you move the taskbar to one of the 4 zones, then unhide it, it seems to fix the issue, I did this about 10 days ago and it is still working, usually when I unhide my taskbar it will stay unhide for about 10 minutes, I think maybe moving the taskbar re-writes the defective file. Give it a try.. |
| Stopping user changing the auto-hide taskbar setting | Vista General | |||
| Taskbar Problem with Auto-hide | .NET General | |||
| Taskbar Auto-hide - Turn On or Off | Tutorials | |||
| Taskbar Auto-hide No Longer Works | General Discussion | |||
| Hide Vista Taskbar (without using auto-hide)? | Vista General | |||
