| | Problems... Well at the minute... NON. Ok, I may not be a power user or a super technical admin, but tbh Vista (as a beta version) has delivered well. I mean easy installation, ok there are name changes and had to play around in the Network section but it was quick, simple and easy to connect to my Private network etc... I now feel more confident to install it on one or more of my other comps, or whateever. Well one question, how do I turn Aero Glass on? thanks |
| | Re: Problems... It's in the Personalization, Change you color scheme. Check the enable transparent glass box. To get to it, right click the desktop. But you must have the hardware to support it. "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message news:8A7B3A58-7309-421D-9E38-3966AF4EAA43@microsoft.com... > Well at the minute... NON. Ok, I may not be a power user or a super > technical > admin, but tbh Vista (as a beta version) has delivered well. I mean easy > installation, ok there are name changes and had to play around in the > Network section but it was quick, simple and easy to connect to my Private > network etc... > > I now feel more confident to install it on one or more of my other comps, > or > whateever. > > Well one question, how do I turn Aero Glass on? > > thanks |
| | Re: Problems... AH! Hardware lol, well the first comp I installed on had one weakness, the graphics card lol. Well as I have already said, I think I will install on a better performance comp and probably use it more than XP lol! Anyone else generally like using Vista more than XP? "Mario Rosario" wrote: > It's in the Personalization, Change you color scheme. Check the enable > transparent glass box. > To get to it, right click the desktop. > > But you must have the hardware to support it. > > "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message > news:8A7B3A58-7309-421D-9E38-3966AF4EAA43@microsoft.com... > > Well at the minute... NON. Ok, I may not be a power user or a super > > technical > > admin, but tbh Vista (as a beta version) has delivered well. I mean easy > > installation, ok there are name changes and had to play around in the > > Network section but it was quick, simple and easy to connect to my Private > > network etc... > > > > I now feel more confident to install it on one or more of my other comps, > > or > > whateever. > > > > Well one question, how do I turn Aero Glass on? > > > > thanks > |
| | Re: Problems... If you do not see transparency in the Task Bar with all programs closed it is possible that you do not have a WDDM compliant video adaptor or it does not yet have a WDDM driver. Look in the middle of the Welcome Screen and you should see a message under the name of your video adaptor that refers to "WDDM." If not you may not have Glass. "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message news:8A7B3A58-7309-421D-9E38-3966AF4EAA43@microsoft.com... > Well at the minute... NON. Ok, I may not be a power user or a super > technical > admin, but tbh Vista (as a beta version) has delivered well. I mean easy > installation, ok there are name changes and had to play around in the > Network section but it was quick, simple and easy to connect to my Private > network etc... > > I now feel more confident to install it on one or more of my other comps, > or > whateever. > > Well one question, how do I turn Aero Glass on? > > thanks |
| | Re: Problems... Too many bugs, system slow downs, non-existent drivers and software incompatibilities to even consider using it for anything other than a novelty at this point. So yeah, I like it much better, but only in test mode! "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message news:970A63B8-25E3-4C9D-B098-CCA3DA24BE0E@microsoft.com... AH! Hardware lol, well the first comp I installed on had one weakness, the graphics card lol. Well as I have already said, I think I will install on a better performance comp and probably use it more than XP lol! Anyone else generally like using Vista more than XP? "Mario Rosario" wrote: > It's in the Personalization, Change you color scheme. Check the enable > transparent glass box. > To get to it, right click the desktop. > > But you must have the hardware to support it. > > "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message > news:8A7B3A58-7309-421D-9E38-3966AF4EAA43@microsoft.com... > > Well at the minute... NON. Ok, I may not be a power user or a super > > technical > > admin, but tbh Vista (as a beta version) has delivered well. I mean easy > > installation, ok there are name changes and had to play around in the > > Network section but it was quick, simple and easy to connect to my > > Private > > network etc... > > > > I now feel more confident to install it on one or more of my other > > comps, > > or > > whateever. > > > > Well one question, how do I turn Aero Glass on? > > > > thanks > |
| | #6 (permalink) |
| | Re: Problems... I think Microsoft designed Vista to be adaptive. The more problems you have with it, the harder it becomes for you. "Mark D. VandenBerg" <mvan103@hotmail.com> wrote in message news:83EFB858-9632-4D2B-8BC3-281D2BFE2FD9@microsoft.com... > Too many bugs, system slow downs, non-existent drivers and software > incompatibilities to even consider using it for anything other than a > novelty at this point. So yeah, I like it much better, but only in test > mode! > > > "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message > news:970A63B8-25E3-4C9D-B098-CCA3DA24BE0E@microsoft.com... > AH! > > Hardware lol, well the first comp I installed on had one weakness, the > graphics card lol. > > Well as I have already said, I think I will install on a better > performance > comp and probably use it more than XP lol! > > Anyone else generally like using Vista more than XP? > > "Mario Rosario" wrote: > >> It's in the Personalization, Change you color scheme. Check the enable >> transparent glass box. >> To get to it, right click the desktop. >> >> But you must have the hardware to support it. >> >> "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message >> news:8A7B3A58-7309-421D-9E38-3966AF4EAA43@microsoft.com... >> > Well at the minute... NON. Ok, I may not be a power user or a super >> > technical >> > admin, but tbh Vista (as a beta version) has delivered well. I mean >> > easy >> > installation, ok there are name changes and had to play around in the >> > Network section but it was quick, simple and easy to connect to my >> > Private >> > network etc... >> > >> > I now feel more confident to install it on one or more of my other >> > comps, >> > or >> > whateever. >> > >> > Well one question, how do I turn Aero Glass on? >> > >> > thanks >> > |
| | #7 (permalink) |
| | Re: Problems... ![]() "Mario Rosario" <mario@webacre.com> wrote in message news F0783D4-1B0D-40C8-ADCD-AF7BE8DC0871@microsoft.com...>I think Microsoft designed Vista to be adaptive. The more problems you have >with it, the harder it becomes for you. > > "Mark D. VandenBerg" <mvan103@hotmail.com> wrote in message > news:83EFB858-9632-4D2B-8BC3-281D2BFE2FD9@microsoft.com... >> Too many bugs, system slow downs, non-existent drivers and software >> incompatibilities to even consider using it for anything other than a >> novelty at this point. So yeah, I like it much better, but only in test >> mode! >> >> >> "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message >> news:970A63B8-25E3-4C9D-B098-CCA3DA24BE0E@microsoft.com... >> AH! >> >> Hardware lol, well the first comp I installed on had one weakness, the >> graphics card lol. >> >> Well as I have already said, I think I will install on a better >> performance >> comp and probably use it more than XP lol! >> >> Anyone else generally like using Vista more than XP? >> >> "Mario Rosario" wrote: >> >>> It's in the Personalization, Change you color scheme. Check the enable >>> transparent glass box. >>> To get to it, right click the desktop. >>> >>> But you must have the hardware to support it. >>> >>> "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message >>> news:8A7B3A58-7309-421D-9E38-3966AF4EAA43@microsoft.com... >>> > Well at the minute... NON. Ok, I may not be a power user or a super >>> > technical >>> > admin, but tbh Vista (as a beta version) has delivered well. I mean >>> > easy >>> > installation, ok there are name changes and had to play around in the >>> > Network section but it was quick, simple and easy to connect to my >>> > Private >>> > network etc... >>> > >>> > I now feel more confident to install it on one or more of my other >>> > comps, >>> > or >>> > whateever. >>> > >>> > Well one question, how do I turn Aero Glass on? >>> > >>> > thanks >>> >> > |
| | #8 (permalink) |
| | Re: Problems... LOL !! -- Jane, not plain 64bit enabled ![]() Batteries not included. Braincell on vacation ![]() "Mario Rosario" <mario@webacre.com> wrote in message news F0783D4-1B0D-40C8-ADCD-AF7BE8DC0871@microsoft.com...>I think Microsoft designed Vista to be adaptive. The more problems you have >with it, the harder it becomes for you. > > "Mark D. VandenBerg" <mvan103@hotmail.com> wrote in message > news:83EFB858-9632-4D2B-8BC3-281D2BFE2FD9@microsoft.com... >> Too many bugs, system slow downs, non-existent drivers and software >> incompatibilities to even consider using it for anything other than a >> novelty at this point. So yeah, I like it much better, but only in test >> mode! >> >> >> "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message >> news:970A63B8-25E3-4C9D-B098-CCA3DA24BE0E@microsoft.com... >> AH! >> >> Hardware lol, well the first comp I installed on had one weakness, the >> graphics card lol. >> >> Well as I have already said, I think I will install on a better >> performance >> comp and probably use it more than XP lol! >> >> Anyone else generally like using Vista more than XP? >> >> "Mario Rosario" wrote: >> >>> It's in the Personalization, Change you color scheme. Check the enable >>> transparent glass box. >>> To get to it, right click the desktop. >>> >>> But you must have the hardware to support it. >>> >>> "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message >>> news:8A7B3A58-7309-421D-9E38-3966AF4EAA43@microsoft.com... >>> > Well at the minute... NON. Ok, I may not be a power user or a super >>> > technical >>> > admin, but tbh Vista (as a beta version) has delivered well. I mean >>> > easy >>> > installation, ok there are name changes and had to play around in the >>> > Network section but it was quick, simple and easy to connect to my >>> > Private >>> > network etc... >>> > >>> > I now feel more confident to install it on one or more of my other >>> > comps, >>> > or >>> > whateever. >>> > >>> > Well one question, how do I turn Aero Glass on? >>> > >>> > thanks >>> >> > |
| | #9 (permalink) |
| | Re: Problems... Hello Jane C. "Jane C" <jellybean@NOSPAMxjgarage.org> wrote in message news:B1BD7D22-479D-4385-82ED-06158BAC88B9@microsoft.com... > LOL !! > > -- > Jane, not plain 64bit enabled ![]() > Batteries not included. Braincell on vacation ![]() > "Mario Rosario" <mario@webacre.com> wrote in message > news F0783D4-1B0D-40C8-ADCD-AF7BE8DC0871@microsoft.com...>>I think Microsoft designed Vista to be adaptive. The more problems you >>have with it, the harder it becomes for you. >> >> "Mark D. VandenBerg" <mvan103@hotmail.com> wrote in message >> news:83EFB858-9632-4D2B-8BC3-281D2BFE2FD9@microsoft.com... >>> Too many bugs, system slow downs, non-existent drivers and software >>> incompatibilities to even consider using it for anything other than a >>> novelty at this point. So yeah, I like it much better, but only in test >>> mode! >>> >>> >>> "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message >>> news:970A63B8-25E3-4C9D-B098-CCA3DA24BE0E@microsoft.com... >>> AH! >>> >>> Hardware lol, well the first comp I installed on had one weakness, the >>> graphics card lol. >>> >>> Well as I have already said, I think I will install on a better >>> performance >>> comp and probably use it more than XP lol! >>> >>> Anyone else generally like using Vista more than XP? >>> >>> "Mario Rosario" wrote: >>> >>>> It's in the Personalization, Change you color scheme. Check the enable >>>> transparent glass box. >>>> To get to it, right click the desktop. >>>> >>>> But you must have the hardware to support it. >>>> >>>> "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message >>>> news:8A7B3A58-7309-421D-9E38-3966AF4EAA43@microsoft.com... >>>> > Well at the minute... NON. Ok, I may not be a power user or a super >>>> > technical >>>> > admin, but tbh Vista (as a beta version) has delivered well. I mean >>>> > easy >>>> > installation, ok there are name changes and had to play around in >>>> > the >>>> > Network section but it was quick, simple and easy to connect to my >>>> > Private >>>> > network etc... >>>> > >>>> > I now feel more confident to install it on one or more of my other >>>> > comps, >>>> > or >>>> > whateever. >>>> > >>>> > Well one question, how do I turn Aero Glass on? >>>> > >>>> > thanks >>>> >>> >> > |
| | #10 (permalink) |
| | Re: Problems... 2 quck tricks that I learned last week to verify if Aero is on: 1) Use Alt + Tab to see if you've got thumbnails 2) Use WinKey + Tab to see if you've got Flip3D turned on - John "Colin Barnhorst" wrote: > If you do not see transparency in the Task Bar with all programs closed it > is possible that you do not have a WDDM compliant video adaptor or it does > not yet have a WDDM driver. Look in the middle of the Welcome Screen and > you should see a message under the name of your video adaptor that refers to > "WDDM." If not you may not have Glass. > > "marc.nutty" <marcnutty@discussions.microsoft.com> wrote in message > news:8A7B3A58-7309-421D-9E38-3966AF4EAA43@microsoft.com... > > Well at the minute... NON. Ok, I may not be a power user or a super > > technical > > admin, but tbh Vista (as a beta version) has delivered well. I mean easy > > installation, ok there are name changes and had to play around in the > > Network section but it was quick, simple and easy to connect to my Private > > network etc... > > > > I now feel more confident to install it on one or more of my other comps, > > or > > whateever. > > > > Well one question, how do I turn Aero Glass on? > > > > thanks > > > |
| Big vista problems need help icon/background/graphics/personalise problems | Vista performance & maintenance | |||
| laptop start up problems and problems in general | General Discussion | |||
| Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 | Vista General | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
