Vista Tutorial - SD Card using ReadyBoost increases CPU to 100%
Old 09-20-2007   #11 (permalink)
Stephan Rose
Guest
Re: SD Card using ReadyBoost increases CPU to 100%
On Thu, 20 Sep 2007 19:24:34 +0100, dennis@xxxxxx wrote:
Quote:
> "Stephan Rose" <nospam@xxxxxx> wrote in message
> news:QP6dnVTYs9fHNm_bnZ2dnUVZ8rKdnZ2d@xxxxxx
Quote:
>> On Thu, 20 Sep 2007 14:50:08 +0100, dennis@xxxxxx wrote:
Quote:
>>> "Stephan Rose" <nospam.noway@xxxxxx> wrote in message
>>> news:0oednbo29Mb39m_bnZ2dnUVZ8sninZ2d@xxxxxx
>>>> On Thu, 20 Sep 2007 04:05:09 -0700, rminnis82 wrote:
>>>>> Well thats not actually true. The X41 has 1.5Ghz Centrino with 1.5GB
>>>>> RAM and when the SD card is added it makes a massive difference.
>>>> Yea, I can see the massive difference it is making by your original
>>>> post. Your entire system becomes laggy, I admit, that's quite a
>>>> massive difference.
>>> Have you been taking lessons in reading from alias? The OP said quite
>>> clearly that it works perfectly in the X41 but not in the other.
>> Yes and I am responding in regards to the one that doesn't work.
>> Now, what exactly did you contribute with your post?
> Well you appear to have got the idea that it has made his x41 slow and
> laggy which it hasn't.
> Its his other one of the two that has the problem. So my post should
> have cleared that up for you.. but maybe it didn't. Maybe you are just
> so keen to get in a bad word you didn't read it properly?
Where did I mention the model number x41? Where did I say that?
And no, I don't need you to clear anything up for me.
Stephan
2003 Yamaha R6
君のこと思い出す日なんてないのは
君のこと忘れたときがないから
Old 09-20-2007   #12 (permalink)
dennis
Guest
news:QP6dnVbYs9enUW_bnZ2dnUVZ8rKdnZ2d@xxxxxx
>>>>> massive difference.
Well its conventional to be commenting on the quote above your reply when
quoting in-line.
I suppose you may choose to be replying to something else if you want to
confuse people.
That OK but please try to clear things up for the rest of us not blessed
with sixth sense then.
Old 09-20-2007   #13 (permalink)
David
Guest
Stephan Rose wrote:
Quote:
>> Well thats not actually true. The X41 has 1.5Ghz Centrino with 1.5GB RAM
> Yea, I can see the massive difference it is making by your original post.
> Your entire system becomes laggy, I admit, that's quite a massive
> difference.
Quote:
>> The Z60m has the maximum 2GB RAM combination possible, and any extra
>> help in a slot never to be used cant be bad.
> Actually yes it *can* be bad.
> Flash memory is by magnitudes slower than RAM. Adding it to a system as a
> substitute for RAM helps with systems around 512 megs of RAM or so that'd
> otherwise be constantly writing to the HDD instead. And even there,
> improvements can't really be guaranteed.
> If you already have 1.5 gigs of RAM, you're looking at next to nothing to
> gain by adding Flash memory.
> Even on systems where ready boost has been reported to actually give some
> improvements, any improvements started to disappear at the 1 gig mark on
> any benchmarks I've seen so far.
FWIW I have 2GB of ram and I see a slight improvement in responsiveness
with a 2GB SD card. Granted it's not like "night and day" but it's
better than not using it. The laptop it's in has a card reader activity
light, and I see it flicker often, so it's doing its thing. ONLY
because I got the card on sale ($19.99) do I feel it was worth the
effort. I'd feel foolish had I spent north of $40 for the card. YMMV.
Dave
Old 09-20-2007   #14 (permalink)
rminnis82
Guest
I think I need to put a few things straight...
The X41 (1.5GHz 1.5GB RAM) improves with ReadyBoost.
The Z60m (2.00Ghz and 2GB RAM) gets the CPU overload with ReadyBoost.
BOTH machines have the maximum RAM configuration so adding more RAM is
out of the question. Both machines respond well without the SD cards,
but after the visible improvement in the X41 I did the same for the
Z60m.
Whether paging is bad or not is irrelevant, I just want to know why
the Z60m gets CPU spikes when ReadyBoost is enabled...??? As
ReadyBoost should surely cause the opposite!!
Old 09-20-2007   #15 (permalink)
dennis
Guest
<rminnis82@xxxxxx> wrote in message
news:1190325824.923634.176630@xxxxxx
> Z60m.
Do they both use the same SD card reader hardware and drivers?
Old 09-21-2007   #16 (permalink)
rminnis82
Guest
Different SD card readers, but I have installed the latest drivers for
both direct from the IBM website (both Vista drivers).
When ReadyBoost is NOT enabled on the Z60m, the SD card works as it
should. The issue I am having only occurs WHEN ReadyBoost is enabled
on the SD card.
Old 09-21-2007   #17 (permalink)
Frank
Guest
> on the SD card.
Have you tried disabling ReadyBoost on that card while in that laptop,
reformatting the card then enabling ReadyBoost?
Also be sure and go into device manager and under Disk drives enable in
properties on the card, "optimize for performance".
Frank
Old 09-22-2007   #18 (permalink)
JohnRankin
Guest
ReadyBoost - same issue - 100% of one CPU
Same problem here, but I did not know the source was an SD card. I simply found one of my 2 CPUs running at 100% and the cause ultimately was ReadyBoost. Disabled it and things are again normal.
May experiment by reenabling it, then inserting an SD card, but it sounds like this problem is generic to Vista?
I also have an iPod, SmartPhone, SD cards, and CompactFlash cards. Any one of these may have been the trigger.
Comptuer is HP Paviliion desktop d4790y wih Core 2 Duo / 2.4GHz.
EggHeadCafe - .NET Developer Portal of Choice
http://www.eggheadcafe.com
Old 09-22-2007   #19 (permalink)
dennis
Guest
Re: ReadyBoost - same issue - 100% of one CPU
"JohnRankin" wrote in message news:2007922131146johnandrew@xxxxxx
It sounds like its a problem with particular drivers and/or hardware to me.
People report it working with SD cards on some machine but not on others..
Vista is common but the drivers and hardware are not.
Someone needs to compile a list of not working hardware and drivers to see
if there is a common problem.
Old 09-24-2007   #20 (permalink)
Spirit
Guest
My suspicion is A: the USB Drive has mixed memory, enough FAST so it passes
the
ReadyBoost test and then does not function properly. B. indeed there is a
USB driver
problem or conflict. Many cheap drives do used mixed memory.
ReadyBoost Drives - Compatible
http://www.grantgibson.co.uk/misc/readyboost/
http://www.activewin.com/reviews/har...adyboost.shtml
ReadyBoost Incompatible
http://www.grantgibson.co.uk/misc/re...s=incompatible
"dennis@xxxxxx" <dennis@xxxxxx-ass.net> wrote in message
news:4D560326-7720-429E-88AF-FD3D1D660FC4@xxxxxx
> me.
Readyboost - which 2GB SD card? Vista performance & maintenance
Readyboost - which 2GB SD card? Vista General
SD Card for ReadyBoost? Vista hardware & devices
Best for ReadyBoost: USB vs. SD Card Vista hardware & devices
Readyboost and a USB 2.0 card Vista hardware & devices
Designer Media Ltd
