| | #21 (permalink) |
| Member | Re: SD Card using ReadyBoost increases CPU to 100% I have two IBM ThinkPads, X41 tablet and Z60m running Windows Vista Business installed in exactly the same procedure. Both have SD card slots so I bought 2 SanDisk Extreme III 2.0GB SD cards setup for full use on ReadyBoost as I wouldn't use these card slots for anything else. The X41 with the SD card works perfectly. BUT when I enable ReadyBoost in the Z60m, the CPU starts running at 100% and the HDD light starts to flash and the whole system becomes laggy. If I disable ReadyBoost, the CPU returns to normal. I have changed cards around and its not the cards. I have formatted both cards, no change. I have reinstalled latest driver for SD Card Reader from IBM and no change. The issue is purely a ReadyBoost one...anyone had the same problem or might know where I could have gone wrong? |
| | #22 (permalink) |
| Guest | Re: SD Card using ReadyBoost increases CPU to 100% I built my own computer with an AMD motherboard and about two weeks ago svchost.exe started taking up 100% of the cpu making the machine worthless. With the Vista Community help I traced it to Readboost and disabled the service returning my computer to a healthy state. I don't have a handle why this started happening; however, two weeks ago was the first time I used a memory stick in the computer just to transfer some files and then removed it using the remove hardware function. Does anyone have any ideas is this a "new feature" of Vista. gsaxton825 "nowhereman" wrote: Quote: > > rminnis82;457510 Wrote: Quote: > > I have two IBM ThinkPads, X41 tablet and Z60m running Windows Vista > > Business installed in exactly the same procedure. Both have SD card > > slots so I bought 2 SanDisk Extreme III 2.0GB SD cards setup for full > > use on ReadyBoost as I wouldn't use these card slots for anything > > else. > > > > The X41 with the SD card works perfectly. BUT when I enable ReadyBoost > > in the Z60m, the CPU starts running at 100% and the HDD light starts > > to flash and the whole system becomes laggy. > > > > If I disable ReadyBoost, the CPU returns to normal. I have changed > > cards around and its not the cards. I have formatted both cards, no > > change. I have reinstalled latest driver for SD Card Reader from IBM > > and no change. > > > > The issue is purely a ReadyBoost one...anyone had the same problem or > > might know where I could have gone wrong? > Looks like windows updates, when you have installed make it so crapp > things. > > > -- > nowhereman > |
| Readyboost - which 2GB SD card? | Vista performance & maintenance | |||
| Readyboost - which 2GB SD card? | Vista General | |||
| SD Card for ReadyBoost? | Vista hardware & devices | |||
| Best for ReadyBoost: USB vs. SD Card | Vista hardware & devices | |||
| Readyboost and a USB 2.0 card | Vista hardware & devices | |||
