Vista - Upgrade from Vista Home Basic to Home Premium
Old 09-20-2007   #1 (permalink)
subrajit
I bought a compaq laptop in India and it came with Vista Home Basic. Since
I need to develop web applications which need IIS connectivity, so I was
planning to upgrade to the vista home premium version. I am currently in the
US right now. Can I go for a upgrade out here even if I had bought my system
in India? If not what is the procedure I need to follow.
Besides on clicking on the upgrade button in my control panel, I was asked
to insert a CD during upgradation, which was supposed to come with the
purchase. But i dont remember having any such upgrade CD. Can you tell me
what needs to be done now.
Thanx,
Subrajit
Old 09-20-2007   #2 (permalink)
PhilBiker
RE: Upgrade from Vista Home Basic to Home Premium
The CD/DVD it is asking for is the "Anytime Upgrade" disc. Most windows
Vista version DVDs are "Anytime Upgrade", meaning they have the entire OS,
but only the parts of it which belong in your version are "activated".
Theoretically you can "Anytime Upgrade" and only have to download a key code,
the isntall would work from your original disc. In many cases like yours
(and mine) you need to actually buy an "Anytime Upgrade" disc.
I don't know about your country situation. Hope this helps.
Old 09-20-2007   #3 (permalink)
Kathryn
The anytime upgrade disk should have come with your pc when you purchased it,
that was kind of standard procedure for all oem's so you may have gotten it,
but don't remember because you didn't have to use it to install vista, if by
chance you didn't you should be able to get one for free from the oem simply
by calling and asking for one. As for the Country situation, I would suggest
that you do purchase the upgrade license while you are in the US because
Microsoft will not let you run the upgrade from outside the US, I ran into
this problem as well after I purchased my laptop with vista home basic and
wanted to upgrade to home premium(I live in Mexico) and you will get an error
saying that the upgrade is not available in your Country. I was finally able
to do it using my oem's(Acer) website (thank God for that) but my advice to
you would be to purchase the license while you are here, then you can install
it anytime that you want to, just save the license on your pc or a flash
drive and also save it in your digital locker and that way it will never be
lost and as long as you have it you can install the upgrade anytime anywhere.
If you know someone in the US(a business assoc. or friend) who has vista you
could ask them to borrow their upgrade disk to install, but you should
deffinently look into getting your own because if something happens and you
need to re-install vista you will need the disk.
<a href="http://pc-videogamesandmore.gooforum.com">Game Forums</a>
Re: Vista Home Premium 64 bit Upgrade from Vista Home Basic 32 bitoperating system Vista installation & setup
how to upgrade from Vista Home Basic to Home Premium? Vista General
Re: Anytime Upgrade from Vista Home Basic to Home Premium Vista installation & setup
Home Basic to Home Premium (Without Upgrade Anytime DVD) Vista General
Upgrade from Home Basic to Home Premium question. Vista installation & setup
