Control Panel Not Responding
  1.    02 Jul 2006 #1
    Jim Yount Guest
    I have had this issue on a Sony Vaio dual-core 3Ghz with 1GB RAM, 250GB
    drive. Both Beta 2 public release and Build 5456. When I launch Control
    Panel it is empty. If I click on the window, then it goes to not responding
    forever. Also experiencing multiple issues of Windows Explorer not
    responding. The only other software installed is Avast Antivirus software.
  2.    02 Jul 2006 #2
    usasma Guest
    RE: Control Panel Not Responding
    I used Avast on my laptop last week with build 5456 and it hogged almost
    every resource that the system had.
    I'd suspect driver issues and vid card issues. Check the manufacturer
    (Sony) for Vista drivers - and ensure that your vid card is the equivalent of
    an nVidia FX 5200 or higher. If not, you're gonna have problems. My laptop
    has "nada" for graphics and it was slow as molassess (but it runs fine on my
    home system) - primarily due to the graphics card.
    - John
  3.    02 Jul 2006 #3
    Jim Yount Guest
    Re: Control Panel Not Responding
    Thanks. I narrowed down to the Sigmatel audio driver. Unfortunately, I can'
    t find a Vista supported driver for the built-in audio. Of course, Sony said
    to contact MS..........
    "usasma" <usasma@discussions.microsoft.com> wrote in message
    news:54C29703-01E1-4629-BACF-9B0B4E9D9B94@microsoft.com...
    > of
    > laptop
    > my
  4.    03 Jul 2006 #4
    Andre Da Costa [Extended64] Guest
    Well Sony is partly responsible. I would file a report anyway:
    For Feedback:
    http://go.microsoft.com/fwlink/?linkid=55160
    Feedback reporting tool:
    http://go.microsoft.com/fwlink/?linkid=43655
    Andre
    Extended64 | http://www.extended64.com
    Blog | http://www.extended64.com/blogs/andre
    http://spaces.msn.com/members/adacosta
    "Jim Yount" <jimyount@nospam.com> wrote in message
    news:uU%239vMlnGHA.1444@TK2MSFTNGP02.phx.gbl...
    > can' t find a Vista supported driver for the built-in audio. Of course,
    > Sony said to contact MS..........
    >> equivalent
    >> of
    >> laptop
    >> my
  5.    03 Jul 2006 #5
    MICHAEL Guest
    My laptop uses Sigmatel, also. When I first installed Vista,
    I had no sound. Vista even told me there was an update
    available- it did not work either. I went to Gateway's site
    and downloaded the last audio installation update they had
    for XP. I ran that installation program in Vista- it worked,
    I had sound. Vista then let me know that update was available
    again. Feeling brave, I tried it. I just knew that, "if it ain't broke
    don't fix it", was gonna happen. But, my sound still worked
    after the update and sounds great, too.
    It is hit and miss on what works and what doesn't work and
    the paths folks take to get things working. Some XP installation
    routines and drivers work in Vista, some don't. Some of
    the installs need to be ran in Compatibility mode, some don't.
    For instance, I couldn't get Picassa2 beta to install until I ran
    the install in Compatibility mode. Thinking I would also need to
    run the actual program in Compatibility mode, I checked that in
    the properties of the icon. Well, Vista spazed out a few times
    when running it. So, I unchecked the Compatibility mode to see
    what would happen- Picassa2 beta works great, now.
    One last observation, sometimes when installing a hardware
    device the setup.exe won't work. But, using update driver and
    pointing it to the location of the files, that seems to work at times
    when the installation program won't.
    FYI, I didn't use Compatibility mode when I ran the installation program
    for my Sigmatel sound. As always, YMMV.
    -Michael
    > Thanks. I narrowed down to the Sigmatel audio driver. Unfortunately, I can' t find a Vista
    > supported driver for the built-in audio. Of course, Sony said to contact MS..........
    >> of
    >> laptop
    >> my
  6.    03 Jul 2006 #6
    Leo Guest
    On my Viao, the original Sony sound card driver works fine. YMMV.
    Yesterday is a canceled check; tomorrow is a
    promissory note; today is the only cash you have.
    Spend it wisely.
    >> equivalent
    >> of
    >> laptop
    >> my
  7.    04 Jul 2006 #7
    Chad Harris Guest
    Re: Control Panel Not Responding--Use this regedit
    Usama--
    To restore your control panel, try clicking this>yes to accept.
    http://www.kellys-korner-xp.com/regs...ionrestore.reg
    Or if you feel more geeky happy editing the ole reg directly than bop on
    down to:
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
    "NoControlPanel"=dword:00000000
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
    Also see:
    Open your registry and find the key below.
    Create a new DWORD value, or modify the existing value called
    'NoControlPanel' set the value to equal '1' to enable the restriction.
    Exit your registry, you may need to restart for the changes to take
    effect.
    (Default) REG_SZ (value not set)
    NoControlPanel REG_DWORD 0x00000001 (1)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\...
    Registry Settings
    User Key:
    Explorer]
    System Key:
    Explorer]
    Value Name: NoControlPanel
    Data Type: REG_DWORD (DWORD Value)
    "One last observation, sometimes when installing a hardwaredevice the
    setup.exe won't work. But, using update driver andpointing it to the
    location of the files, that seems"
    Excellent point by Michael. I've found that you increase chances of getting
    a driver in,up and running in Vista builds if you do this vs. any other type
    of driver install.
    CH
    "MICHAEL" <u158627_emr@dslr.net> wrote in message
    news:%23XbJ%23nsnGHA.4604@TK2MSFTNGP02.phx.gbl...
    > -Michael
    >> can' t find a Vista
    >> MS..........
    >>> equivalent
    >>> of
    >>> laptop
    >>> on
    >>> my
  8.    09 Aug 2006 #8
    =?Utf-8?B?VGhlQ29vbA==?= Guest
    I just wanted to state that I'm having the same problem. I install the
    driver, either in compatibility mode or not and the driver goes in fine but
    from then on the Control Panel hangs Windows Explorer every time. And Windows
    Explorer crashing as always been a problem in Windows since 95. I have to go
    back to a previous restore point to get my Control Panel working again. So
    there seems to be a problem with either the app that the Sigmatel driver is
    installing into the Control Panel or the icon is a problem. Is there a way to
    edit the control panel without opening it so I can test this. Cause my laptop
    without sound is not an option, and not being able to use the control panel
    isn't an option either.
    TheCool
    > Spend it wisely.
    > >> equivalent
    > >> of
    > >> laptop
    > >> my
Parental Control Report Not Responding
I have 3 accounts on my Vista pc, mine, and one each for children. One child, no problem viewing report; the other, every time I choose Websites...
Vista General
How can I control the size of icons in Control Panel?
The size of icons in Control Panel suddenly became very large. I don't see any way (as I had in XP and even in other parts of Vista) to change the...
Vista General
volume control applet not responding
what causes my volume control applet to freeze ! Also my computer will not shut down because explorer.exe is still running ! thanks for your input!
Sound & Audio
Lost Control of Control Panel
I am running Vista Ultimate on one machine and Vista Home Premium on another machine. Something has happened to the Control Panel on the Ultimate...
Vista General
Control Panel, Autoplay not responding...
So many problems.. don't know if they are related? I was trying to install itunes with quickplay. I get some error message about not being able to...
Vista General
Control Panel
For some reason, everytime I try to open my control panel, it opens for a split second and closes itself.
Vista account administration
control panel
HI can anyone tell me why my control panel is now being unresponsive? i click on it to open it, it then flashes onto the screen and then goes away,...
Vista performance & maintenance
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • Old server
    About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
