| Guest | Why did my Volume icon disapear from the system tray? It has been there for months. I rebooted today and it is gone. right click on the start menu, select properti, notification area......volume is greayed out so I can't select the check box. The volume still works though. How do I get it back? Why would it just disapear? thanks |
| Guest | Re: Why did my Volume icon disapear from the system tray? Try Logging Off, then back On. I don't know why it happens, though. It has happened to me, occasionally, as well. "SwampYankee" <1@xxxxxx> wrote in message news:MPG.215cce8865c15a5d989697@xxxxxx Quote: > It has been there for months. I rebooted today and it is gone. right > click on the start > menu, select properti, notification area......volume is greayed out so I > can't select the > check box. The volume still works though. How do I get it back? Why > would it just > disapear? > thanks |
| Guest | Re: Why did my Volume icon disapear from the system tray? "SwampYankee" <1@xxxxxx> wrote in message news:MPG.215cce8865c15a5d989697@xxxxxx Quote: > It has been there for months. I rebooted today and it is gone. right > click on the start > menu, select properti, notification area......volume is greayed out so I > can't select the > check box. The volume still works though. How do I get it back? Why > would it just > disapear? > thanks for your soundcard or removing and reinstalling those drivers. You might also check the soundcard manufacturer's website for the latest Vista compatible drivers. Sometimes drivers can become corrupted and need to be reinstalled in order to correct issues that result from the corruption. -- Michael Solomon Backup is a PC user's best friend DTS-L.Org: http://www.dts-l.org/ |
| RE: Network Icon and Volume Control gone from tray | Vista General | |||
| Network Icon and Volume Control disappeared from tray | Vista General | |||
| Network and Volume icons gone missing from System Tray | Vista General | |||
| Shortcut to Volume Control other than in system tray? | Vista General | |||
| Volume control on the system tray does a disappearing act | Vista General | |||
